Question about Nintendo Super NES Console
My super nes has a scrambled picture and good sound. just dug it out of storage it was working when it was put away. borrowed my buddies input cord from an n64 and still does it. any suggestions?
  • Nintendo Master
  • 427 Answers
Other Screen Problems
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
Slide the Power Switch on the Control Deck to the ON position.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Posted on Nov 02, 2012
3 Suggested Answers
  • 1340 Answers
SOURCE: Can you hook up a super nes without AV cords?
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Posted on Jul 23, 2010
  • 291 Answers
SOURCE: N64 and NES reset randomly
Well you know on how computers will redo them selves when they have an error in their software and programming so you see that an n64 consoles parts are similar to a computers piece but a simpler software so when it does the resetting it says im going to fix it but since that its impossible fro it to fix its self it will just only keep reseting over and over again then.
Posted on Oct 17, 2011
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
No picture
Well I had heard of the metal piece of the back of a super NES console round piece breaking off because it becomes loose over time periods or it can rust and then fall off. So to fix this problem you need to find another super NES console and swap the parts, if you find a broken SNES console with working internal parts you are able to switch the parts into the other one that you have and buy a bypass plug from Radio Shack the Source or circut city to put it back toghter. But it would be more easy to buy a new console and sell this one as it is.
Feb 25, 2012 | Nintendo Super NES Console
I have a super nintendo but not sure if i have the right cords i was woundering if you would know the numbers that are on the back of the cables or the power cable thanks
Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
After the system is connected to the TV:
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
Mar 10, 2011 | Nintendo Super NES Console
When i turn my snes on, the tv screen shows scrambled pictures of the game for a second and then goes black but the audio works just fine. the music continues playing. ive tried three different cords....
Well try cleaning the game packs out with qutips and rubbing alchoal it sounds lIke a glitch then that can occure sometimes with the old consoles
Nov 23, 2010 | Nintendo Super NES Console
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
Jul 23, 2010 | Nintendo Super NES Console
Super nintendo turns on but not picture or sound
if you've tried 2 other super nes' and still no picture and sound.. don't you think it's the "yellow,red,white" cables that might be an issue? doesn't sound like a power cord is the issue at all if it's getting power to the "red light".... get a new y,r,w cable (sry.. tired and forget the name)
Sep 25, 2009 | Nintendo Video Game Consoles & Games
Sound but, no picture on my super nintendo
I fixed the problem. It was only some dust in the connector, but I can't still understand why the RF out is broken.
May 14, 2009 | Nintendo Super NES Console
NES console - intermittent, varying static sound
Your possibly using a wierd RF channel, try putting your tv at channel 3 or 4 and use the channel selecter on your NES accordingly
Mar 30, 2009 | Nintendo NES Console
Super nes
Super Nintendo doesn't work with new TV's.
Jun 26, 2008 | Nintendo Super NES Console
Picture only lasts a few seconds
THE DEAL IS YOU MUST TAKE A HAIR DRYER AND MAKE BLOW IT ON A PARTS INSIDE SPECIALLY THE FLYBACK SECTION MAYBE IT WAS CAUSE OF HUMIDITY
Mar 16, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Nintendo Super NES Console Logo
137 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
