Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do I remove the fabric softener dispenser, Whirlpool, I wanna check replace agitator parts
  • 4,340 Answers
The softener just pulls off, straight up. Then there is a bolt that holds the top agitator on. When you put it back together, be careful to align the tabs, they are very easy to miss and bend, then break.
Posted on Jan 01, 2011
GE washer model # WHDRR418E4WW : Having trouble removing the plastic cap under the fabric softener dispenser, so I can access the agitator bolt.. There appears to be no simple way to remove it. There are...
that's right just put your fingers under agitator and pull up,under the agitator is a coupler that has a screw in it,whirlpool has the nut in there,if you have a problem with the agitator not moving the clothes around that coupler wears out and has to be replaced.
Oct 07, 2017 | Washing Machines
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
Is the fabric softener dispenser at the top of the agitator replaceable?
Yes it is,although the whole peice running half way down will probably have to be purchased..It's called the(Clothes Mover)it has finns running down & can be removed by a bolt down the centre after removing the top cap.
May 21, 2010 | Whirlpool LSR5132PQ Top Load Washer
Fabric Softener Dispenser Broken
Part # 8566491 it runs around $50.00 and it just snaps into place you can find/order at http://www.whirlpool.com/catalog/parts_and_accessories.jsp  Or any local appliance parts distributor you can find in the yellow pages.
Sep 13, 2009 | Washing Machines
How do you remove an agitator from a ge washing machine. I removed the fabric softener dispensor, but there is a clear plastic cover underneath that cannot be removed.
Well, first we have to determine if it is a Whirlpool washer or a GE washer, as they are quite different. I'm going to assume its a Whirlpool. When you remove the fabric softener dispenser from the center of the agitator, there is an opaque plastic cover under that. It must be removed to reveal the agitator retaining bolt underneath it. They can be quite hard to get out sometimes, you just have to be persistent. If you break it, it is replaceable as a separate part, part number W10074580.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Does the agitator in our machine have a fabric softener dispenser?
softner only ..liguid bleach goes in dispenser on right front corner
Sep 07, 2008 | Whirlpool Washing Machines
Agitator Dogs
take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
721 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
