Question about RCA RP-9518 Boombox
RCA RP-9518 Audio system Will not play CD's. AM and FM work. Loaded with 5 CD's. Green lights 1 thru 4 blink and code rd appears Light 5 does not blink and code nd appears. Tried skip and shuffle but does not play. Skip seems to work but nothing plays. Tried cleaner CD but will not play. Ideas? Thanks.
Bob Gemmell
  • 209 Answers
SOURCE: every disc in tray ends with noise after a minute
Try a cd cleaning disc, the ones you can buy with the small cleaning brushes on them! It sounds like the laser is dirty.
Posted on Sep 13, 2007
VOTIT
  • 2071 Answers
SOURCE: RCA audio system,and three disc.
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Posted on Jun 15, 2008
SOURCE: cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Posted on Oct 15, 2008
SOURCE: How to get in to clean the lens for RP-9316 Boombox
I had the same issue. Over time, the cd player quit palying at all. The unit would try to read the cd but couldn't and then skip to the next cd.
- I took fairlane's advice and put a cd in and listened for the ticking sound to indicate that the laser was trying to read the cd. I also looked inside through the top "vent" area to be sure the cd was actually spinning. It was spinning and I heard what I thought I was "ticking" sound so I guessed that the laser needed to be cleaned.
- I took off the 6 side panel screws on the right side of the entire unit and loosened the screw on the backside off the unit about halfway down from the top that also held the side panel on.
- I then removed the side panel.
- I then removed the 2 screws on the top side of the other side panel and the screw in the top center back of the top panel and was able to remove the top cover that is over the unit. The top cover is "pressure fitted" in so be careful as you try to remove it, using a little wiggle at a time, but it does comes off.
- Once you have the top off, there is a screw in the center of the plate that holds the tray for the cd's. Remove the screw and you will able to lift and spin the tray to have clear access to the laser
that needs to be cleaned. (Note the position of the numbers on the tray so you put it back the right way.)
- The laser is a little "glassy" looking thing about the size of the head of the q-tip.
- I used the q-tip with 70% isopropol alcohol and rubbed it over and around the laser as best I could. I repeated the procedure 2-3 times and the used compressed air to dry it off.
- I put everything back in place in the reverse order I took it off, based on what's in the above steps.
- Remember, the top will fit in with pressure so don't get anxious as you try to get it in the right position.
The cd's actually play again.
I hope this will help someone.
Posted on Jan 03, 2009
rscheutz
  • 54 Answers
SOURCE: RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Posted on Mar 22, 2009
What is the universal remote code for an RCA RP-9316 Audio system?
Please let me know what brand your universal remote is and the model so I can further help you. Usually, there is a sticker under the battery cover that tells you what model it is. I would be glad to help.
Sep 16, 2014 | RCA RP-9316 Boombox
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Lost my instructions to operate the remote control. I have the code list, but i don't know how to imput the right code on the remote. My model is JER321
Configuring codes:
Turn on the component that you want to set up.
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jul 30, 2010 | Jensen JER-321 Remote Control
I LOST MY INSTRUCTIONS LIST FOR MY REMOTE CONTROL DEVICE....THE MODEL IS JER321
Configuring codes:
Auto Code Scan:
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. 7.If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jul 30, 2010 | Jensen Televison & Video
Need to know how to program a jenson jer 323 with a Sharp tv
Configuring codes:
Auto Code Scan:
Thanx
Jul 29, 2010 | Jensen JER-323 Remote Control
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
Cds won't play
im in the same boat as you...we have one of those as well and the cd's wont read...only the fm and tape work
Mar 16, 2009 | RCA Audio Players & Recorders
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
RCA RP-9518 Boombox Logo
371 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
