Question about Whirlpool Dryers
I have an ESTATE model EED4300TQ0. When The start button is pressed, the dryer only hums, it doesn't tumble. Can you help with this?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Model EED 4300TQO Dryer is cycling (turning) but has stopped heating.
Hi.
Start checking and eventually replacing the thermal fuse. That is the first part to replace when there is no heat. The fuse can be tested using a multimeter set on Ohms to make sure that its contacts are not open (impedance across its terminals is not Ohms infinity).
If the Fuse is not the problem test thermostats (there are three of them) and element itself. The parts have different impedance values. If any of the parts shows no continuity (circuit open), then the part must be replaced.
Here all parts and diagrams
Replacement parts for WHIRLPOOL EED4300TQ0
Here a repair of a different model showing in some more details testing procedures.
Aug 30, 2011 | Estate EED4300TQ Electric Dryer
When you press the start button it doesn't turn on - just clicks.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Jul 29, 2011 | Estate EGD4400WQ Dryer
Whirlpool dryer. When pressing the start button the motor humms. It keeps humming until opened or unplugged. Does seem to generate heat though.
maybe a broken belt, here is a website that will assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 13, 2011 | Whirlpool LGR7648KQ Dryer
When you press the start button, the motor hums but won't run.
heatman101
Jan 02, 2011 | Estate EED4100SQ Electric Dryer
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
Estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
Jan 22, 2009 | Estate EED4300SQ Dryer
Dryer will not tumble
HI your right on the money , it is the belt. replace thanks.
Oct 11, 2008 | Maytag PYE4557A Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
