Question about Asko 24 in. D3350 Dishwasher
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the water inlet tubing (after powering up so as to open the solenoid) and there does not seem to be any blockages. Thanks, Mike
  • Asko Master
  • 1,902 Answers
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Posted on Jan 01, 2011
I want a special catalog, operation and maintenance
F1? Water supply/low water fill ?· Check water supply to machine
?· Replace water inlet valve "F2? Water level too high ?· Plugged/Bad water pump
?· Faulty water valve "F3? Pump problem Check pump trap and clean. "F4? Thermistor problem ?· Open thermistor, replace
?· Bad wiring to thermistor "F5? Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes ?· Check heating element
?· Check thermostat "F6? Motor fault ?· Check wiring to motor
?· Replace motor if necessary "F7? Door lock release fault ?· Bent pull-rod for door latch
?· Bad door latch solenoid "00 00? Machine did not spin Check load for out of balance Redistribute load and restart
Sep 30, 2016 | Washing Machines
HET4 hf code
it's a water problem.is water filling into the washer or no water?
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1pUAisxSH
Mar 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Fill fault on top tub and bottom works fine. getting about 30 ounces of water and it takes about 3 minutes for fault code to come up
If your bottom drawer works fine then your inlet water valve below the bottom drawer is bad. Click on the link below to see how to repair this dishwasher.
Appliance Repair Video
Mar 26, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Kenmore Elite Smartwash Quietpak 9 HE 4t - Model 11045991400. Have been getting FH code on and off for past two years. Clean filters on top and bottom. Sometimes I would unplug and reset ckt breaker and...
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
-Verify inlet valve operation.
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
8. Verify CCU operation by running a Diagnostic test or any cycle.
Your tech sheet is behind the service panel How to Access it.
Dec 15, 2010 | Washing Machines
The awm8103 not working it writing FH .what its mean?
I have not seen this but from the online fault code listing says that these are the conditions for the failure:
Or
And the things to check are:
Check inlet valve operation
Check Drain pump operation
Check there is not a siphon problem
Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check pressure switch operation
Check flow meter operation
Check CCU operation
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#ixzz0ufpGdihe
http://www.appliancepartspros.com hope this helps
Jul 25, 2010 | Whirlpool AWM8103/1 Front Load Washer
No water entering machine - mains supply OK
On a Whirlpool ADP4731 dishwasher, try this...
Double check that the under-sink valve is open, providing hot water to the dishwasher.
If it is, the water inlet valve should be checked for proper operation.
The F4 error code means "drainage fault" which should be checked after the water inlet problem has been resolved.
Good Luck!
Apr 08, 2009 | Dishwashers
Hello lilo1
Welcome
You said, You are getting an error code F/H but it works most of the time. Then it just quits
You may have low water pressure which the machine senses and after some minutes will shut down .
If any pump runs with insufficient water pressure it will burn out the pump so washers are made with auto shutoff's in those case it does shut off.
Check that the water valves are passing water out of the taps that are connected to the washer and they did not fail.
When you remove the water supply hose from the washer inlet, you will probably find the screens in the washer water inlet are blocked and need to be removed and cleaned off and then replaced.
Do not bend them up and you can re use them!
Below are causes and more remedies
Let me know how it goes!
Huuum
Please remember to leave a rating?
F/H Error code
Or
Check/Repair
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Oct 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Verify CCU operation.
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washerf
Failure
Code
Condition
Check/Repair
F/H
Or
  • Verify CCU operational
Nov 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
243 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
