Question about Activision Tony Hawk: Shred
I cant get shred board to calibrate with xbox 360 console
Two of batteries that came with the board where almost 1.6volts while the other two where1.52 volts I changed out the batteries that came with board and game with 4 used AA batteries. Then moved the board back about 5'9 inches and this worked. I believe it is due to a high DC battery Voltage that causes this problem. I retested this again useing the higher voltage and got the same errors. then changed back to correct voltage and the board calibrated right away. This solved my problem. I hope this helps you. Make sure you test your batteries with a multi meter to make sure they are around 1.2volts to 1.52volts any higher than this gave my kids board a calibration problem. good luck hope this helps.
Posted on Jan 02, 2011
Tony hawk shred for the xbox 360 will not calibrate
http://www.youtube.com/watch?v=Zp311lU2Ejs
If that doesn't work, there have been many reports of users being unab;e to calibrate because of the lighting in the room (too bright, too dim, both can affect the sensor), lighting from the TV (again, too bright or dim). Try turn the board parallel to the TV, so you'll be side on to the TV.
May 06, 2011 | Activision Tony Hawk: Shred
How to set up tony hawk shred board. on the tv it says to connect the board, and the light on the board keeps blinking green
You need to connect the board to the XBOX before you can calibrate...press the Connect button on the main console (on my XBOX 360S it is directly to the left of port 1 for the game controller), then press and hold the tiny button far left on the board controller. That's as far as I got, it won't calibrate to save my life!
Dec 26, 2010 | Activision Tony Hawk: Shred
My xbox 360 tony hawk shred board won't calibraite
we spent a day trying to calibrate the shred board, after much searching on the internet we found the solution that worked for us straight away was too - put two old and two new batteries in the board, we also elevated the board on a small stool this did the trick and now we can actually use it. Huray!!!
Cant get the board to calibrate. Tryed everything
try using two old batteries and two new batteries, also why calibrating try putting the board on a small stool - this worked for us. Good Luck!!!
Dec 25, 2010 | Activision Tony Hawk: Shred
I can't get my Tony hawk shred controller to connect
Use older batteries. Do not use the batteries that came with the board. After you switch the batteries re-calibrate and it should work fine.
Tony hawk shred board will not calibrate even with enough clearance all around keeps saying something did not go through.
I had the same problem. Do not use the batteries that come with the board. Use slightly older batteries and re-calibrate the board, this should work.
CANNOT CALIBRATE XBOX 360 SHRED BOARD. kEEPS SAYING "something didn't go through, lets try it again
I had the same problem. Do not use the batteries that come with the board. Use slightly older ones. After switching the batteries re-calibrate the board and that should do the trick.
Cant calibrate Tony Hawk Shred controller board to Xbox 360. followed all instructions but with no success
Don't waste your time!! Throw the piece of **** in the trash!! I have been trying to get it do work must of the day also. Tired all the tricks posted around the net. My wife bought this junk off Ebay, so we are basically out $80.00. For those who can return yours, run don't walk and get your money back.
Why wont my xbox tony hawk bord callobrate
  • Return to the main menu and select "Options", then select "Calibrate Board" and follow the onscreen instructions. Make sure to follow the steps exactly and hold the board in the calibrating
  • Nov 20, 2010 | Microsoft Xbox 360 Wireless Controller
    Cannot get the skateboard controller to calibrate on tony hawk ride xbox360
    hey i cant get my board calibrated for some reason i keeps coming up as try again
    Dec 25, 2009 | Microsoft Xbox 360 Wireless Controller
    Activision Tony Hawk: Shred Logo
    182 people viewed this question
    Top Activision Video Game Consoles & Games Experts
    Person On the...
    Level 1 Expert
    dj ese
    Level 1 Expert
    James Wishart
    Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
