Question about Belkin Basic Wireless Router
Does this work with apple tv? - Belkin Basic Wireless Router
    President:
  • 2,653 Answers
Yes.
Posted on Jan 01, 2011
How do i connect apple tv to marantz 5040 TV with no hdmi port?
Apple says you can't, however, there is one solution.
First, Apple, and then using a HDMI to RCA Converter Box in the link.
Set up your Apple TV To get started with your Apple TV, follow these steps.
Here's what you need
And using an HDMI to RCA digital analogue converter
How to Connect Apple TV to an Old Analog TV
Dec 04, 2017 | Marantz Televison & Video
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
My iphone dont see Apple TV
You will have to download apple app remote from iTunes to make the connection work
May 19, 2013 | Apple TV MD199LL/A
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
Apple tv or Apple av adapter for ipad2 on tv
Unless you realy need wireless, then get the av adapter as the Apple TV has very noticeable lag.
Nov 23, 2011 | Apple Ipad2 32GB Wifi
I am trying to connect my new apple tv to my panasonic bt205 ht and then to my samsung tv. As I have only i HDMI socket in my Ht I bought a HDMI splitter. This doesn't seen to work. If I connect the...
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
Aug 04, 2011 | Audio Players & Recorders
Just bought a used apple tv 1st generation and it blinks yellow and white even after I reboot it. It also shows the apple tv with a blinking question mark on my tv screen. How do I fiix to make it work and...
[1] You can restore an Apple TV (1st generation)'s software from the main menu by selecting Settings > General >Reset Settings > Factory Restore.
If you are unable to reach the settings menu, try the following [2]:
  • Press and hold both Menu and down (-) on the Apple Remote for 6 seconds or until the status light blinks amber.
  • The Apple TV should Reset itself and show you a screen where you can select one of the following: Restart ,Run Diagnostics o rFactory Restore. Select Restart.
  • [1] http://support.apple.com/kb/ht3199 [2] http://www.methodshop.com/gadgets/tutorials/appletv-fix/index.shtml
    Jan 14, 2011 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
    The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
    I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
    Gerry
    May 01, 2009 | Bose Lifestyle 20 System
    Belkin Basic Wireless Router Logo
    56 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
