Question about Kenwood KDC-MP342U Car CD Player
Won't play cd reads toc error - Kenwood KDC-MP342U Car CD Player
I've had this happen with my stereo a few times too. i'm not sure why exactly it does it but it seems to only happen with a burned cd. i just took the cd out and made sure it was clean and put it back in. although sometimes i'd have to do it several times before it would read it. but it usually works eventually for me
Posted on Jan 11, 2011
4 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: TOC Error
Burned ones? Or do "real" CDs do it, too? If ALL do, then the laser was damaged or misalligned and will have to be serviced.
Posted on Sep 22, 2007
hawkwatcher
  • 67 Answers
SOURCE: TOC ERR for kenwood cd player
Most likely optical pickup is defective. I may be able to get a pdf service manual if you wanted to try repairing yourself kstahl65@att.net
Posted on Jan 27, 2008
tech48
  • 624 Answers
SOURCE: toc error
I have repaired many of these cd players working at an authorized Kenwood service center for over 17 years.
There are only 2 things you can do as the end user of this unit.
1. Try cleaning the disc's. If the cd has any fingerprints or scratches on the inner most part of the cd, the laser will not be able to read the TOC. It is the first thing the cd player tries to do and if that fails for any reason, the disc can not be played at all.
You can purchase a disc cleaning kit, or you can do what I do. I spray a small amount of windex on the data side of the disc and then clean it with a soft cloth like a bath towel or terry cloth. This works as good or better than the cleaning kits and is much cheaper.
If that does not work you can go to the next step.
2.. Clean the lens of the laser with a cd cleaning disc. They can be purchased at many stores that sell cd players and music cd's.
You put it in the player and let it run about 20 to 30 seconds and then you eject it.
If neither of these things help, you most likely have a bad laser pick up. You will need to take it to an authorized Kenwood service center and you can count on the repair being anywhere from $120 to $175. Depending on the rates and the mark-up of the laser pick up.
This is a very good car stereo, and is probably worth the repair cost, but it does have a 2 year warranty. It is not too old, so it may still be under warranty. If so, the repair is free for you.
I hope this helps you with this problem, and if so, a good rating is always appreciated.
Let me know if you have any other questions about it.
Posted on Jun 22, 2008
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
TOC READ
I have the same problem... Any solutions?
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
TOC error
toc stands for table of contents error if it is a copied cd it is probably how it was written if not do other cds work?
chris
Oct 29, 2007 | Kenwood KDC-8024 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP342U Car CD Player Logo
260 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
