Question about Canon PIXMA MP150 All-In-One InkJet Printer
I have E code then a 3 showing up, printer will not pull paper through, can find no paper jam..
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Press the black or color button.
If this does not work.
Unplug the printer from electrical outlet.
Wait at least 2 minutes.
Do not just unplug and replug.
Plug back in printer.
This will reset the printer.
The printer will recycle during startup.
Posted on Jan 01, 2011
Paper jammed open left cover
Hello, To solve this problem try follow this steps
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays, inspect them for wrinkled or damage paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly
The goal is to keep the paper from tearing. If several pieces are jammed together,try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper.
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Jun 29, 2011 | Office Equipment & Supplies
After paper jam printer displays error light and will not function
1. Step 1
2. Step 2
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
5. Step 5
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
9. Step 9
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
Paper Jam at the printer
please do the following sir: 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Feb 09, 2010 | IBM Infoprint 1612 Express Printer
How do I fix a paper jam?
Step 1
some or all of the jam.Many printers provide an error-code listing
on the front panel display for the area where the jam occurred.If
jam occurred.
Step 2
Step 3
Step 4
Step 5
If necessary,remove the toner or ink cartridge.Place it in a bag
Step 6
If you find a piece of jammed paper,remove it by holding it with
both hands and pulling firmly.If several pieces are jammed together
Step 7
If the paper does tear,try rotating the roller gears manually to
free the paper.
Step 8
Replace the toner or ink cartridge and paper trays,close any doors
Step 8
If the printer paper jam message still appears,then there is still
some paper in the printer.Reinspect the paper path.
Oct 28, 2009 | HP DeskJet 810c InkJet Printer
Paper jams when printing and paper is being pulled in sideways
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. Thanks! mannu_rakesh
Sep 07, 2009 | Lexmark Z1480 InkJet Printer
Paper jam
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Dec 04, 2008 | HP Office Equipment & Supplies
Paper-jam
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Oct 17, 2008 | Canon i860 InkJet Photo Printer
Paper jamming
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Sep 05, 2008 | HP PhotoSmart 7760 InkJet Printer
Paper Jam feeder
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Paper jam
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Nov 07, 2007 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
26 people viewed this question
old marine
old marine
