Question about Dishwashers
Bosch dishwasher cycle doesn't end
Example: when regular wash cycle is selected, two hour shows in window.
Problem is, it continues to run longer than the two hours, inface it runs for hours!!, after the two hours. Stays on 1 minute.
ser. FD8006200152
Assume that the circuit board needs to be replaced??
Have had this unit for 8 years, this has been the only problem.
Thank you for your recommendation
Gary
  • 1 more comment
  • Anonymous Jul 23, 2008
    2 Hour cycle will run all day and never get to the rinse or dry cycle. This appliance is over 10 years old. Any one have suggestions?
  • Anonymous Jan 08, 2009
    I have the same problem with my Bosch dishwasher. Also, when it gets stuck on 1 minute, the cycle switches from regular wash to rinse and hold. Any attempt to manually switch it back to a regular cycle results in brief execution of that cycle, followed by the dishwasher switching itself back to rinse and hold, and sticking at one minute remaining.
  • Anonymous Jan 31, 2009
    My Bosch logixx is doing the same. It is sporadic though; ie sometimes works fine then other times stays stuck on 1 minute. When it sticks on 1 minute the dishes will be clean but still wet rather than dry.
  • 3 Answers
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Posted on Mar 01, 2009
I have a Bosch SHE 58 C05UC/40 dishwasher. I've replaced the control unit once already and now I'm having the same problem again with the unit taking forever to cycle (12-16 hours for regular wash. cycle).
Attached is a pic of the control unit PCB board. Below that are closeups of the PCB where it appears to corrosion of some sort. Does anyone have any idea what it is and how this could make the board fail ? Or is there any way to fix it?Bosch dishwasher cycle doesn't end - f2167770-6a44-4aa5-8f80-11c2ce393947.jpg5a457d53-a9c3-4417-a081-f0078ecf947b.jpg
Posted on Apr 08, 2013
  • nagraj kadam
    nagraj kadam Feb 14, 2014
    I want wiring diagram of SHE58 series dishwasher
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher no longer counts down the cycles, keeps running
UNfortunately that sounds like the controle module and you can not have that fixed. only replacement of the part will fix that problem
HERE you can find the drawing and parts. You can also order them here
Nov 29, 2008 | Bosch SHU5316UC Dishwasher
Bosch 3030 wash cycle does not advance beyond mid-point
The cycle timer is hanging at mid-point. You may have to replace it.
Oct 19, 2017 | Dishwashers
Runs all the time
I just had this problem. I found an article that explained it and had the exact picture of my problem. It is http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/ .
I am watching my the dishwasher just move into the rinse cycle as I type this. My guess is that I just saved either $400 for a repair or $1000 on a new dishwasher. I think it is time for me to make a donation to that article's author.
Mar 18, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
4,623 people viewed this question
Top Dishwashers Experts
