I have a marshall MG100HDFX/MG412 slant cab half stack. There seems to be something wrong with the head. It will not turn on. The redlight and the fan do not turn on. I have tried almost everything like replacing the power chord that goes into the outlet. Nothing has worked. I'm guessing that it is something internally. Any suggestions would be greatly appreciated. Thank you very much, Henry Kaye HBKaye@mac.com
Have you opened it to check the fuse?
Posted on Nov 21, 2008
Can some one tell me how to hook up my half stack.
Using a speaker cable, plug head 16 ohm output to cab 16 ohm input, making sure the cab switch is set to mono if it's a stereo cab (1960)
Oct 01, 2013 | Marshall Amplification Marshall JVM410H...
I have 2 marshall mg100hdfx heads, i want to run them together, how do i wire them?
You have to use seperate speakers for each. These are not designed for any form of "bridged" operation.
You would have to wye the inouts from your source.
Jan 08, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
No head!
They were designed to be used with the Marshall MG100HDFX heads.
Jun 30, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall mg100hdfx loud fuzz and distortion and no guitar sound
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Jun 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Feedback noise when overdrive is on
it could be your guitar pickups. try using another guitar or getting your pickups waxed at your local music store. also if your playing in a small room kind of loud, or if your using single coil pickups (like fender statocaster pickups) you will definitely get a feedback noise. if that does not work let me know.
May 10, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
76 people viewed this question
 Grubhead
Grubhead
