Question about Toys
Thomas' midnight ride motorized engine instructions manual
2 Suggested Answers
SOURCE: need instruction manuals for thomas
Here is how Shake Shake bridge goes together:
On the bottom of each piece is a letter. Here is how the letters fit together to form an oval. Bridge is A and the other straight track is F you also have 2 B's & 2 C's
going clockwise: A - B - C - E - F - D - C - B
The 2 tall supports go under the junctions at B & C on either side and the small supports go under the junctions at C & D and C & E
Posted on Mar 07, 2011
Water damaged ride on thomas the tank engine.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 27, 2012 | RC Thomas the Tank Engine
Need instruction manuals for thomas the train shake shake bridge and midnight ride.
Jan 26, 2011 | Toys
My thomas the train ride on toy wont move unless you assist it by turning the wheel after pressing the go button
A few things can cause this: The battery is weak/bad. The connector at the battery might be worn out and have intermittent contact. Those are fairly easy things to check. Next, the GO button might be worn out internally (high resistance contacts)-believe it or not, the whole motor current goes through that switch. You would need to remove top of the roof to access the button. Or, open the speaker cover, pull out the control board and bypass Go switch wires to check for train proper operation. As you are already there, inspect the control/sound board. The last thing that comes to my mind is the motor itself, it is under the seat. Check contacts to motor, plus you can spray contact cleaner or, if you don't have anything else, alcohol. Avoid using WD40 - it does the job, but collects new dirt very very fast). There is always a chance of pinched/loose wire, or mechanical problem with gear assembly/jamming or so.
Oct 02, 2010 | RC Thomas the Tank Engine
Thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Apr 03, 2010 | Peg Perego Ride On Santa Fe Train
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
Thomas the Tank Engine, Sodor Post Office Train Track
http://www.thomasandfriends.com/usa/news_product_info.asp
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
Robert
Please take a moment to rate this solution thanks
Jan 29, 2009 | Seth Thomas Thomas The Tank Sodor Engine...
Toys Logo
523 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
