Question about Enflick TextNow Free - Unlimited Texting and Picture Messaging
Text now keeps giving me a connection failure - it can't talk to the textnow servers. I'm connected to my home wi-fi. any thoughts/suggetsions?
3 Suggested Answers
SOURCE: forgot my password for textnow.
send it to my email
Posted on Jun 09, 2011
forgot my password ccan you give it t me this my E.mail abcjul123@textnow.me
Posted on Dec 10, 2011
How can I connect to the server on my lg-vs700 Verizon phone?
Hi Sharon, try turning your cell phone off then on.... If still no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 07, 2016 | Cell Phones
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
How do I fix my talk to text feature?
The "Cannot Connect" message indicates that your device is not able to access the internet, either through your cellular service provider (ie. Verizon, AT&T, T-Mobile, etc.) or through a Wi-Fi router if you happened to be connected to one. You must have a data plan in order to gain access through your provider. Also check the settings on your phone to make sure you are connecting to a Wi-Fi if you happen to have access to one at home or work place.
May 08, 2014 | Android Huawei
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
CONNECTED TO WI-FI, BUT DOESN'T HAVE INFORMATION
You should turn off your Wi-Fi (on your server) and then you should turn it on again. It should work. It has worked for me.
Jun 19, 2009 | Apple iPod touch
Wi-fi connection
When Safari says it can not find the server it means it can not find a good or strong enough wi-fi connection. The sever is basicaly just a wi-fi connection that you connect to. You need to find a good connection in order to get on wi-fi.
May 21, 2008 | Apple iPod touch
Enflick TextNow Free - Unlimited Texting and Picture Messaging Logo
181 people viewed this question
Top Enflick Apps Experts
Nikki  Mclean
Nikki Mclean
Tom Chichester
Veronica
Level 1 Expert
Are you an Enflick App Expert? Answer questions, earn points and help others
