We can't seem to keep the connection satble. For some reason if we move the printer shelf in our out to load paper or scan an item the cord "shorts" out. Fairly often there is a message thet the HP printer is off line or disconnected bacause of this issue.
    Sergeant:
    Novelist:
  • 179 Answers
First is to try replacing the cable with a new one that you know is good and see if that solves it.
The second is that the female USB port on the printer may have been damaged. I've seen this on a number of occasions, and it causes just what you're seeing. Unfortunately, repairing the USB port is an expensive proposition in most cases (unless you're quite close to an HP repair station) and most folks who find this is the issue just get a new printer.
Hope that's helpful.
Posted on Jan 01, 2011
How do I fix paper jam for AV122C
Sounds like the machine is picking up a signal from the paper exit sensor. The flag is not moving freely, or not moving at all. Look down in the paper hopper, ( where the paper is loaded), you might be able to see the sensor. The flag is spring loaded. Sometimes the flag falls off. The flag is black and shaped like a (T).
May 11, 2014 | Avision AV122 Color Duplex 18ppm/36ipm CCD...
Picking up multiple sheets at once
The most common reasons for jams and misfeeds I run into are over-loaded paper input trays, dampness in the paper, and pages that have not been fanned prior to loading.
Most paper trays have an indicator showing the maximum amount of paper that can be loaded.
Make sure you have selected the correct menu settings for the weight and texture of the paper.
Before you load the paper flex, fan, and straighten the paper.
Don't store you paper on the floor, try to keep shelf and avoid setting heavy objects on top of stored paper.
If the problem is not solved by these steps, you could have dirty or misaligned input rollers. Fixing this may require service at a repair center.
Oct 29, 2013 | Dell 2350dn Laser Printer
IT WONT COPY OR SCAN
Please try this approach:
  1. Remove the sheets of paper from the printer.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  5. When the printer turns on, reinsert the cartridges. Close the printer cover.
  6. Load some paper.
  7. Try to scan or make a copy again to verify that the problem is fixed.
I hope this helps.
Feb 17, 2012 | Lexmark X2600 InkJet Printer
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
The on button light flashing only.
Welcome to FixYa!
A blinking power light for HP DeskJet D2360 means 3 things.
1. The cover is open.
Close the printer cover properly.
2. There is no loaded paper or the paper in the paper tray is not loaded properly.
Load the paper properly in to the paper tray.
3. Paper Jam and/or Carriage Jam.
Follow the instructions below.
> Turn of the printer and unplug the power cord at the back of your printer.
> Open the back door of the printer.
> Remove any paper or foreign object that you see gently.
> Close the back door of the printer.
> Open the front cover of the printer
> Move the carriage (where the ink cartridge sits) left and right. Make sure that it moves freely.
Remove any paper or foreign objects that is preventing it from moving freely.
> Close the front cover.
> Connect back the power cord.
> Turn the printer on using the power button.
If it doesn't not resolve the issue, reset the printer.
1. Turn the printer on.
2. Unplug the power cord at the back of your printer while it is on.
3. Unplug the USB cable at the back of your printer while it is on.
4. Wait for 2 minutes.
5. Connect back the power cord and USB cable.
6. Turn on the printer using the power button.
I hope this will help.
Thanks for using FixYa and keep me posted.
Jas247
Mar 10, 2011 | HP Deskjet D2360 InkJet Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
I keep getting the following error on my Canon 980: C000 printer error has occurred what do i do?
C000 indicates to remove the packing material.
Remove packing material so that the print headholder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both.
Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
    After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.
Jul 18, 2010 | Canon PIXMA MP980 All-In-One InkJet...
My printer is not set up to print yet what do I do
Setting up the All-in-One Follow these steps in order. When you are finished, you can click the appropriate link at the end of this document if you need instructions to install the product software. CAUTION: Do NOT connect the USB cable now. You need a USB cable to connect the product to the computer, but you will be prompted to connect it at the correct time during software installation. Step one: Unpack the All-in-One
  1. Lower the paper tray and remove all packing material. Figure 1: Lower the paper tray
  2. Lower thecartridge door and remove all packing material.
Step two: Check the contents of the box The contents might vary by country/region. See the packaging for a list of items shipped in the box. Step three: Connect the power cord and adapter Connect the power cord and adapter. Step four: Turn on the power
  1. Press the On button
  2. Wait 30 seconds for the product to start up.
Step five: Load plain paper
  1. Pull out the tray extender.
  2. Load plain white paper.
  3. Figure 6: Load plain white paper
Step six: Install the cartridges
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off and then turn it on again. NOTE: The product must be turned on to insert cartridges. Open the cartridge door
  2. Remove the tape from both cartridges. CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 9: Copper-colored contacts
  3. Hold the cartridges with the HP logo on top.
  4. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Make sure to push the cartridges in firmly until they snap into place.
  5. Push the cartridge in firmly
  6. Close the cartridge door
Step seven: Align the cartridges Make sure that paper is loaded in the tray, and then wait a few minutes while the cartridge alignment page prints. After the alignment page prints, place it face-down on the glass and close the lid. Press the Scan button to complete the alignment. Wait until the green On light stops blinking. to see full diagrams please follow the link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00853006&cc=ca&lc=en&dlc=en&product=3177566
Jun 28, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
My HP officejet 6210 all-in-one just stopped working. When I try to fax, copy, or scan, the process starts (i.e. menu acknowledges, hear clicking, etc) but then stalls. The green (on/off) light blinks and...
You can try Full Reset on printer
Disconnect power cord from back of printer ( while printer is on )
While holding the # and 6 button connect the cord back and release the # and 6 after 3-5 seconds..
The printer will turn off and will turn on again.. follow the Alignment process
Note : By doing this Full Reset - you may loose any Speed Dial/Group Dial entry from the printer
Also try changing the Printer Socket, Connect to walljack directly or another socket on the Surge strip.
Jun 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
12 people viewed this question
jasbo
jasbo
