Question about Western Digital Caviar SE WD800JD SATA Hard Drive
How to slave a wd800jd caviar se sata hard disk
  • Western Digital Master
  • 9,587 Answers
Just install it. No jumpers are needed on a SATA drive.
Posted on Aug 16, 2017
4 Suggested Answers
  • 742 Answers
SOURCE: How to make sata hard disk a slave???
Look at the jumper settings. These jumpers are located near the data cable and the power port of the hard disk. Usually by default, this jumper is set to "Master". To make it a slave, just remove the black or blue jumper or please refer to the jumper guide table printed in you hard disk's label.
Posted on Dec 29, 2009
smeago1
  • 136 Answers
SOURCE: Problem with SATA WD Caviar SE WD2500AAJS hard drive model
hey there
there are tiny little jumpers on the hard drive itself there's also a diagram that tells you what jumper to set..basically there's only about 3 options try the other two options then plug it on the mobo and then try to see if the mobo detect it.
one of the option WILL always work.
good luck
smeags
Posted on Jan 02, 2008
darkpain
  • 316 Answers
SOURCE: Western Digital Caviar SE WD800JD SATA Hard
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Posted on Jan 13, 2010
CHANGE WD 400BD HD TO WD 800JD HD
You can add the drive as an additional drive just by setting the drive jumper to slave with master installed and it will give you another drive letter. https://eshop.macsales.com/Tech/manuals/idehdsettings/WD72.pdf
Mar 28, 2014 | Western Digital Caviar SE WD800JD SATA...
Installing used WD800JD into external disk enclosure
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Nov 25, 2012 | Western Digital Caviar SE WD800JD SATA...
I am attempting to connect a 2nd SATA drive just to pull files from it. My system tries to boot from this 2nd drive vs the first drive. are there jumper settings to keep the 2nd drive from being the...
There are pins on the Sata drive that have to be set. The good part is that there is a diagram on the device that will tell you which settings are for Master/Primary and Slave. You want to set it up as a Slave.
Sometime the connection ribbon from *********** board will have master/slave written on them. These also need to be correct depending on the computer.
Jun 28, 2011 | Western Digital Caviar SE WD800JD SATA...
I have 2 HDDs installed on my pc,one is on ATA and it's used as Primary and one is on SATA (WD800JD) and i want to use it as Slave but doesnt appear on My Computer. I have tried with Add Hardware but it...
There should be jumpers on the back of both hard drives. You need to set the primary hard drive jumper to MASTER and the secondary hard drive jumper to SLAVE. Here is a picture of the jumper settings.
I hope this helps you.
Jan 17, 2011 | Western Digital Caviar SE WD800JD SATA...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
My wd hard drive is not detecting. i want to data backup.
Only solution for that is to try to make that WD HD to be ur SLAVE! So that u could get the DATA u wanted!
Nov 29, 2010 | Western Digital Caviar SE WD800JD SATA...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
746 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
