Question about Amana ABB1927DE Bottom Freezer Refrigerator
My side by side is hot between doors. vaccuumed coils
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you really need to blow out the coils with compressed air, a vacuum is not really strong enough.
take a flash lite and make sure all coils are clean, the exception to this is if you have coils on the back of the unit, and not underneath.
last but not least, make sure the fan turns by the compressor..
if you door area is still running hot, you may have a compressor going bad.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Gas in the system is warm, check that the condenser is not blocked up with dust...either on back of fridge or will be on front at bottom behind kick strip. aslo make sure the cooling fan running when compressor running, if a fan is fitted. not 100% sure of this model
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
May 27, 2012 | Sub-Zero 642
Fridgefreezer admrial very hot between doors
It is supposed to be warm it stops them from accumulating moisture. They usually run the hot side of the coils there for that purpose.
Feb 29, 2012 | Admiral 26 cu. ft. Side-By-Side...
Whirpool side by side refrigerator hot door gasket
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Apr 30, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Excessive heat coming from bottom, and the wall dividing the fridge and freezer is very warm and is transferring heat to the door seals that touch it when closed. Is this repairable or on its last leg?
very repairable, the unit is tryin to release exessive heat from lower compartment, pull unit out and vaccuum the coils,as well as underneath the unit, when pulled away form wall, make sure that the fan behind the unit(next to compressor) is running.
Aug 25, 2009 | Frigidaire FRS6R5EMB Side by Side...
Center wall between freezer and refrigerator is hot along the edge in front.
firrst thing you do is check for dirt or clear condesor use a vaccuum and clean condensor blow out any debris you should see a change almost instantly as long as fan is working dirt build up is most likely problem especialy in summer weather
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool side-by-side is getting hot on strip between doors but everything seems to be working fine. Is there a solution? What if it becomes extremely hot??
It will not become extremely hot. It is heated by a thing called a mullion heater. It warms the area so it doesn't sweat and mold in the summertime. It is perfectly normal.
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigirator not cooling up
you need to pop off the gate and really get under there with a shop vac,is the fan in the freezer working?can you pull the frig out to see if the compressor is running,you can put your hand on it to feel if it is running(watch it it might be hot,the only other thing is it might be stuck in defrost,can you find the defrost timer and manualy take it out of defrost,let me know what you find and we can go from there-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge is getting hot in between the doors
This is called a mullion heater and is perfectly normal as this heater prevents the area between the doors from freezing. No danger at all.
Mar 08, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
51 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
