Question about Husqvarna Garden
My Husqvarna 14527E Snow Blower runs fine and pushes snow great. However, I noticed when I get into rough snow, tow layers, the wheels seem to lock in and stop turning, especially in reverse. Once I get it on better ground, it seems to run fine. Is there a slip of some sort built in to protect the machine?
  • 211 Answers
SOURCE: Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: Snow Blower engine runs very rough
YES THE CARBURETOR CAN BE OVERHAULED
THE REPAIR KIT PART # IS 31840 , THE BOWL IS REMOVED BY REMOVING THE BRASS NUT ON THE BOTTOM WITH A 7/16" WRENCH.YOU MAY NEED TO REMOVE THE WELCH PLUGS FOR A GOOD CLEANING. NEW PLUGS COME WITH KIT. YOU CAN SOAK CARB. IN CLEANER SHOULD BE NO LONGER THAN 15 MINUTES. ALWAYS USE NEW GASKETS. ADJUSTMENTS TO BE DONE WHEN ENGINE IS WARMED UP.
Posted on Jan 26, 2009
mister_b_65
  • 74 Answers
SOURCE: I have a 312-8 wheel horse with a snow blower.
check the belt tighteners to see if they are sticking at a certain point, and not putting enough pressure on the belts. The other thing might be that the belts are stretched to the point where they may not tighten any more. Belts that work fine when it's warm out are harder and won't grab the pulleys as well in the cold...especially if they've been glazed from long use.
Posted on Dec 13, 2009
  • 6 Answers
SOURCE: Snowblower seems weak for a 5HP
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
Posted on Jan 06, 2010
SOURCE: craftsman snow blower wheels wont move. Help!
If it is a 5.5 HP dual stage, like mine, it could be that the belt has popped off the friction pulley. If you drain the gas, tip the unit on its "face" and remove the large shield on the bottom you will see a 3" pulley attached to the drive shaft. There will also be what looks like a fan belt floating around in there. That fan belt nees to go on the pullet, as it serves as the friction disk tio drive the wheels. Good luck. this happens to mine ALL the time. very frustrating. :(
Posted on Feb 13, 2010
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Snow blower runs rough, backfires
Clean the choke asembly and air filter .
Dec 26, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
Snow Blower has no power moving forward and jerks
I am wondering if the shear pin is broken in the drive wheels. it could be broken but just grabbing enough to move the machine when not under load. i had a self propelled lawn mower that did that and had to replace the pin in my drive wheels.
Feb 02, 2018 | Garden
Does not seem to have power when pushing snow wheels just keep spinning even with wheel weight and chains
Sounds like power isn't the problem if the wheels keep spinning. Traction is the problem. You say pushing snow, that leads me to think you have a plow on it not a blower. I think this machine is too light for plowing, unless its light fluffy stuff. It would do better with a snow blower. Hope this helps.
Dec 10, 2010 | Yard Man Yardman Riding Lawn Mower 38in...
Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
189 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
