Question about Whirlpool Microwave Ovens
Microwave only works for a second or two then stops & flashes "F7".
    Brigadier General:
  • 8,909 Answers
The microwave flashes F7 due to no current being drawn by the magnetron.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 01, 2011
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Why does my microwave stop working and flash F-9
Since this an LG microwave, an F9 error when the inverter module fails. Unfortunately, other parts could cause the inverter to read as a failure. A bad magnetron, relay 2 or door switches or the connections between the various parts could be bad. Since the microwave is starting, the switches are the least likely culprit. However, it's hard to determine if the inverter or the magnetron is bad without replacing one part. Then the other if the first repair doesn't solve the problem.
I hope this helps.
Mar 19, 2013 | LG Microwave Ovens
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
We have a Samsung MT1044WB/BB/CB. It is a Toast & Bake Microwave Oven. We have never used any function except the microwave oven over the 8-10 years since we bought it new. We have not used it in...
The computer died. Not much you can do with it. After ten years it doesn't owe you anything.
Of course you could bypass the whole timer with a toggle switch if you were MacGyver.
Apr 10, 2017 | Samsung MT1044 1000 Watts Convection /...
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Its got a code coming up saying f7
Most F7 codes are saying the keypad is sticking. Try running your fingers flat up and down across the keypad then horizontally multiple times and see if the F7 code clears. You cna verify this if you unplug the unit and then plug it back in. There should be a pause of about 16 seconds then the F7 code will appear if it is in fact a keypad problem.
Jan 22, 2010 | Whirlpool GH7208XR Convection / Microwave...
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Microwave Ovens Logo
144 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
