Question about Whirlpool GU2300XTVQ Builtin Dishwasher
Top sprayer is not getting water - Whirlpool GU2300XTVQ Builtin Dishwasher
  • Whirlpool Master
  • 3,247 Answers
It is likely the chopper assembly in your dishwasher has got a blockage which is reducing the water the wash pump can send up to the top wash arms.
See this diagram item 6.
Posted on Jan 03, 2011
Wirl pool dishwasher is not cleaning top rack does not get enought pressure
Do you have multiple sprayers or only sprayer for water on the lowest level? If this is the case (only lowest level sprayers), look at how you're loading the bottom rack. If you are putting items that would stop the sprayers, like mixing bowls or casserole pans, that would be stopping the sprayers from hitting the top tier item.
May 23, 2012 | Dishwashers
Top sprayer arm is not cleaning cups any more
Hello. Make sure the water tube that feeds the top sprayer is properly attached and aligned with the water source in the rear of the machine. Sometimes the rear end of the hose gets dislodged and does not feed water to the top sprayer as it should. Joe
May 05, 2010 | Dishwashers
Top water injector not working
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Bissell quicksteamer 1770
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My model is different than yours, but many models are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Feb 22, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell carpet cleaner
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Bissell model 1694 It is not pumping water
Jan 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Proheat 8910 does not spray water onto carpet.
Jan 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Our bissell proheat carpet cleaner model 3750-T will not **** the water and cleaner through. Is there a schemetic available for free on this or a similar model
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My Bissell is a different model than yours, but many are similar.
Dec 22, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell 9400 pro heat steam cleaners sprayers are clogged again...how can I fix this with out taking it to a shop to get fixed?
Nov 05, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 2X Select Upright Deep Cleaner not pumping water to floor. Water is not flowing out of the pouch area into the carpet.
Mar 09, 2008 | Vacuums
Whirlpool GU2300XTVQ Builtin Dishwasher Logo
75 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
