Question about Cameras
Won't take picture. Message on screen reads "SD CARD LOCKED" ? :)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Jan 02, 2011
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 | Cameras
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
I have a stylus 600 model, if i place the memory card in the cam a message will display in the screen..."write something"....what does it mean?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
May 12, 2011 | Olympus Cameras
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Message reads "card is locked." After
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 09, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 27, 2010 | Jazz DV-179 Digital Camera
The message said "card locked" so I bought a new memory card after several attempts to fix it. With the new card in, the message now reads, "card unreadable"
Make sure you're using an SD card, 2GB and smaller. The M537 won't work with higher-capacity SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 03, 2010 | HP Photosmart M537 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
