Question about Sage 3850CF Fly Spool, Carbon, 5-6wt
How do you change the spool on a Sage 3850CF fly reel?
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
I have a minolta autodual 8 film projector but the front reel is turning backwards in the wrong direction. How do I change the direction to turn in the same direction as the back reel.
I assume you haven't put a reel of film onto the projector and looped it through to the back spool. The front spool usually 'freewheels' whilst the film is pulled through the projector and taken up by the motor driven rear spool.
It is possible that the friction drive and/or drive belt have deteriorated with age, as the mentioned projector is a rather elderly 'classic' of the dual 8mm series.
If in doubt, don't risk your family pictures. Try the unit with an old piece of film on small spools.
Dec 26, 2014 | Eumig Imperial P8 Movie Projector For 8mm...
How do you put line on a magda pro star reel
Mount your reel on your rod. Run the line from your filler spool thrthrough the bottom guide of your rod. Pass the line througo the line guide on your reel and tie your line to your reel using an arbor knot. Put a pencil or dowel rod through your filier spool and have someone hold light tension on the spool as you reel line onto your reel.
Aug 03, 2014 | Okuma Magda Pro Linecounter Magda Pro...
How can I get my reel to cast smoothly?
Hey Ken, Neil here from Dark Side Reelz. it boils down to over oiled bearings, or bearings that require cleaning, your spool shaft only rides on 2 or max of 3 points, (depending on reel make) each of those points contains a bearing the spool shaft seats in those bearings any build up will greatly reduce casting distance. I specialize in reel cleanings, rebuilds and restorations as well as custom work like upgrades and super tuning. If you would like to read some really good info on what you can do read this article I wrote http://ezangler.com/tackle-box/gear-tips/the-reel-truth/ here is the link to my webiste as well www.darksidereelz.com
Jul 05, 2014 | Generic Ardent C400 Fishouflage Bass...
How do you change the retrieve to left or right hand on a orvis encounter fly reel ?
Drag factory installed for left-hand wind. To change your real to right-hand wind, remove spool, pull the keyed bush and clicker plate assembly off the spindle. Flip the clutch bearing (silver) and reassemble.
May 21, 2014 | Orvis Encounter Large Arbor Fly Reels &...
How do i fix Nautilus 5/6 wt. fly fishing reel. Re-assemble spool release side.
There are some videos on youtube.com that may help. Nautilus website does not show how to assemble this reel. Nautilus FW hub assy MOV
May 12, 2014 | Fishing
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How do you change reel on 323l trimmer?
TWO TABS INSIDE THE DRUM HOLD THE SPOOL ON. HOLD THE OUTER DRM AND TURN THE SPOOL TO LEASE THE TWO TABS
Sep 21, 2009 | Garden
String is stuck inside reel and I need to remove reel to feed string out again.
Hi, W/D here.
The string tends to get caught in itself, despite our best winding efforts. Pull the spool straight off, and try to get some fingers on the spools as it comes off, in case one of the spools if free, so the line doesn't fly off.
Usually a kinked piece can just be pulled at an angle to free it up.
Best regards, --W/D--
Aug 15, 2009 | Ryobi Garden
Shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Sage 3850CF Fly Spool, Carbon, 5-6wt Logo
135 people viewed this question
Top Sage Sport & Outdoor - Others Experts
Bill Eager
Are you a Sage Sport and Outdoor - Other Expert? Answer questions, earn points and help others
