Question about Rowenta DW8080 Iron
Iron shuts off while being used??? - Rowenta DW8080 Iron
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
My rowenta iron shuts off in the middle of ironing & spits water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 09, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 25, 2010 | Homedics PS-200 Iron with Auto Shut-off
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Auto shut off how to turn back on?
The automatic shut off is a protective device to let the iron cool down when not in use. Normally, if you pick the iron up and sit it down on the board or fabric, the iron will "sense" the motion and click back on to the heating cycle. To turn the iron off, just move the dial to the lowest position, or OFF and or unplug it from the outlet. If left unattended for a while, and when picking it back up to iron, if it does not come back on then you may need to increase the heat setting, move the dial a little, till you see the power light come back on. This is a safety item, and a good one, given the hectic lifestyles we have now, and having busy lives. If we forget to shut the iron off, it does it for itself after a period of non-use. No more trips to the store or wherever and remembering "I forgot to unplug/turn-off the iron I was using". Still, it's best to unplug and or turn it off when not in use. I prefer unplugging, so that it does not be a "vampire device" drawing even little amounts of current when not in use. And it's safest when unplugged and cool.
Sep 26, 2009 | Irons
Dripping brown-spotted water on clothes while ironing.
Your water could have high iron content, therefore empty out the old water and use Distilled water in the iron.
If you are using Distilled water already then it's a problem with the inside of the iron. Get a new iron.
Apr 22, 2009 | Rowenta Effective DX1900 Iron with Auto...
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Iron Shuts off Automatically when using iron.
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 03, 2008 | Conair DPP4000 Iron
Rowenta DW8080 Iron Logo
51 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
