Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
My dimplex coldwatcher 500 cut out because the big cupboard it was in became too hot. It has done this before some time ago and my husband says he reset it by pressing a switch in the back of the unit. However this time he cannot remember what he pressed and we cannot get the unit to work again even if it has been switched off at the mains and then restarted. What to try next? Does the unit have a trip switch or is he imagining it?
On my DIMPLEX LYM28E heater, two of the heating elements start to glow and then cut out. Is there a thermal cutout on these bars?
Let me tell you my experience with a GE clothes dryer that I've had for a long time and had to fix a few times. The thermal switch was a "throw away" - that is, once it activates, it's done and needs to be replaced. This switch was attached to the back-wall of the dryer body and the thermal sensing face was up against the metal surface of the dryer. They "why" it activated (that is kicked off the power to the dryer) is that the body of the dryer was getting too warm/hot from a drying cycle and that activated it. The switch cost about $12 and it consists of a small diameter bi-metalic element that - when it heated up, it pushed its internal contacts apart and kills the power to the dryer. I took the switch apart and the whole process became clear as to why this was happening - not enough ventilation around the dryer. Of course, taking the switch apart killed it so don't expect to use it again. Make sure your dryer is clean of lint around the blower motor and that the exhaust stack is not up against the body of the dryer, or insulate it so if it does touch, its not going to transfer the temperature to the dryer metal.
Oct 21, 2014 | Dryers
I have economy 7 dimplex storage heaters and last winter they just decided to stay stone cold and not come on one day. can these be repaired or do i need to replace the whole heater? thanks
I belive inside the front cover this a bimetal reset in one of the corners top right I think you have to push this back on it makes aloud click . do this with the power off , have done this but a long time ago . hope this helps
Sep 22, 2011 | Dimplex Heating & Cooling
Want to take water hose off from back of the machine so I can feed it down the holes in the cupboard then put it back on can this be done easly or do I have to cut a big hole in the cupboard. cheers
Hi there Larry which hose are you refering to the inlet or the waste. You can take the inlet hose of very easily, However the waste pipe is conected to the waste pump inside the machine. If this is the pipe you wish to remove I would drill a bigger hole in the cupboard. let me know if this helps at all. Regards Gary.
Jul 02, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Heater has two settings for heat and only works on low setting most of the time.
The reason for this is the overheating sensor has cut in. It may just be malfunctioning or in fact it is overheating. This has been a reoccurring problem not just for Dimplex, but other manufacturers as well.
My best advice is contact Dimplex directly and talk with someone in their tech service dept. You can find their home page by doing a Google search for Dimplex's home page.
Jan 26, 2011 | Dimplex Heating & Cooling
I have a Dimplex Fireplace with remote control. I believe the model number to be BF335STP/DXP. We have had this fireplace for almost 2 years. When we have a power outage you have to follow some...
There was a recall on some of the remotes. Check to see if yours is one of them. If you take the plug put of the remote box, and just plug it directly into the wall,it should work.
Nov 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
Dimplex FXL24n wont heat up over night
the clip should click and the heater reset its self have you repalaced the clip ? some times you have to press the clip hard to get it to click
Nov 26, 2008 | Dimplex DS5603 Heater
Subwoofer problem
take a look at the amp is there a light on with the car running and stereo on? if no check the big black ground wire that connects to bare metal somewhere near the amp , also check the big red wire for 12 volts and the small wire for 12 volts let me know -jeff
Sep 12, 2008 | Lightning Audio B1.10.4 Car Subwoofer
Heating & Cooling Logo
74 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
