Question about Samsung SGH-t239 Cell Phone
My phone keeps freezing up then restarts without me touching it. I think it has a virus but i dont know what to do. I didnt let anybody touch it taht might have hacked it. What do i do? My phone model is a SGH-T239
    Problem Solver:
  • 16 Answers
This would usually happen.
If you phone has been hard pressed on? Sat on? Dropped?
If not, try fiddling with the SIM Card. Take it out. Clean In.
Clean Battery & base components & then let me know how you go :)
Posted on Jan 01, 2011
Testimonial: "Well I drop my phone all the time and nothing really happens to it except it gets scratched up. It just started last night when i was checking it. "
  • 1 more comment
  • DMITRY DOROFEEV
    DMITRY DOROFEEV Jan 01, 2011
    Not to sound too rude, but maybe it's heart is literally dying then, lol.
    As phones aren't meant to be dropped constantly.
    In your case go for the Military Standards i-mate 810f build.
    I have the previous model phone to this, but the 810f is;
    (1) Waterproof
  • animeskater2 Jan 01, 2011
    Well i've only dropped it like once or twice and i've only had it for about a year and a half.
  • honeybun1986 Jan 02, 2011
    I suggest you to do a software flash to your phone.If you do not have the kowledge,get it to a repair centre..Do at your own risk.Backup evrything before doing this...
Every time when i turn on my alcatel one touch it freezes up half way then it keeps restarting
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 13, 2012 | Alcatel One Touch C750 Cellular Phone
I have a memoir samsung T929, the problem is the touch screen is freeze, and I can't use the phone or making calls. Also can not access the menu.
Hi,possible problem that makes a phone freezes or have a touch screen freeze is Mainly VIRUS affecting a cell phone.
VIRUS affecting a cell phone is caused by downloading and application that has VIRUS, or through data transfer using a USB cable or transfer through blue tooth device.
When a VIRUS affects a phone,it makes the phone to malfunction and freezes.
To remove the VIRUS attack from a phone, you will need to flash the phone to restore back the phone memory to it's default..
Flashing a cell phone restores back the cell phone to a normal state.
You can use the below link to Know more and how to flash a cell phone.
http://hubpages.com/hub/How-to-Flash-your-cell-phone
Good luck.
Feb 01, 2011 | Samsung Memoir SGH-T929 Cell Phone
It starts normally and than freezes on the touch screen.
hello all you need to do try and get anti virus that will fit the phone,if that does not work then try and change the screen.there are two screen on any touch screen phone.so change the one for the touch screen,if that dont work meaning there is a virus in that phone so its need to be flashed.
thank you for using FIXYA
Jul 28, 2010 | Samsung Cell Phones
Envy Touch freezing and or shutting off
Hi, When a phone freezes, it caused by virus or unwanted applications on your phone.it needs to be flashed, you can use the link to learn more and how to flash your phone.
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | LG enV Touch VX11000 Cell Phone
My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
http://mastermindinaction.blogspot.com/
Aug 26, 2008 | HTC Touch P3450 Smartphone
Stuck on nokia start up screen
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Mar 25, 2008 | Nokia N70 Cellular Phone
Samsung SGH-t239 Cell Phone Logo
173 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
