Question about Kenmore Progressive 35922 Bagged Upright Vacuum
It was running fine for about 15 minutes. I turned it off for a couple minutes and when I turned it on it made a noise and then... nothing. I have let it cool down for a while but it is still not turning on.
  • 6,993 Answers
if it does not turn on, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 01, 2011
What do i do if my jets are not working on my windsor commordore 20
You should be able to take off the jet nozzles and clean them out. You may need a socket wrench possibly to get them out or they may be a quick connect kind that only take a quarter turn to remove the jet from it's holder. I would also suggest running a vinegar/water solution through the system to help clean any chemical residue out of the lines. Put a couple of gallons of hot water in the solution tank with a couple of cups of white vinegar and then plug the unit in and press the solution button and let the solution run for a minute or so and then let it sit over night if you can. Then push the solution button again the nest day and let it run for another minute or so and then drain the vinegar/water solution and put in fresh hot water and run it through for several minutes. Also, soak the jets in some of the vinegar/water solution over night as well and do all of the running of the water with the jets off so that you do not clog them up further. Hope this helps.
Jul 31, 2014 | Windsor Vacuums
My DC31 just stopped working while I was vacuuming my wood floor. Is only 2 mths. old. I bought this for the versatility so I don't have to lug my big Dyson up and down my stairs. The battery was
Don't overlook the obvious. My DC31 just stopped working when I was using it. No lights, no noise, nothing. After poking around for a a couple of minutes, I removed the battery and then re-inserted it. I gave it a good tap with the palm of my hand to make sure it was seated properly. Everything worked after that.
Jun 02, 2012 | Dyson DC31 Animal Bagless Handheld...
Makes clicking noise and runs for a couple of minutes and then says error 2 open roomba and clean brush cage-do that and the same thing happens 2 minutes later
Pet hair often gets sucked into the gear box that drives the brushes and can clog it enough to generate this error. you need to remove the CHM (cleaning head module) and open the gear box on it to clean it out... you can also visit iRobots site and buy a new one that has been redesigned to avoid this issue.
Cheers, immorion
ps check out robotreviews.com for super detailed walkthrough of this process.
Nov 27, 2010 | iRobot Roomba 560 Robotic Vacuum
I was vacuuming with bissell 3750-T and I shut it off and went to turn it back on and will not start or do anything, what is wrong?
If you can't smell burning then it's probably a broken power switch or the vacuum got too hot and the thermal overload protection has tripped. Try leaving it off for 15-30 minutes and try it again. The thermal overload will reset itself during this time and it should work again.
In the meantime, make sure you have power to the vacuum, check for any blockages and check that the rollers in the cleaning head will turn by hand. Also, give your filters a clean. Any of these could cause the vacuum to overheat.
If you've already done this and/or power doesn't return after 15-30 minutes, I would start by checking the switch.
A couple of questions . . .
1. Does the power switch feel "normal" - basically does it have a positive feel when you switch on and off?
2. How long had you been using the vacuum before it stopped working?
Oct 28, 2010 | Bissell 3750 Lift Off Bagless Upright...
I have a Kenmore Elegance Vacuum with Dirt Sensor, Model # 116.30750400C, Serial number M41901532. When vacuuming the carpet the power head will work for 3-6 mins then automatically shut off, power is...
It is an electrical problem in the handle, if you can or know somebody that has any fix it ability it can be fixed in about ten minutes. Oh, and Sears SUCKS!!
Oct 17, 2010 | Kenmore 34612 Bagged Upright Vacuum
Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Easy-Flo 1525 will not turn off
There is a relay back on the master unit. When the hose is plugged into the inlet the metal on the coupling completes the electrical circuit to the relay. In your case the coupling has a split and the circuit continues to the switch in the handle. As long as there isn't any conductive surface left across any of the contacts in any of the inlets, the relay is hung up. I never heard of that happening until today when I responded to the exact same problem on a different machine. The relay needs to be replaced.
The "screeching" on the other hand should have nothing to do with the relay. That sounds like a motor bearing without proper lubication and/or going bad.
May 22, 2009 | Easy Flo EF1400 Central System Vacuum
Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
Kenmore Progressive 35922 Bagged Upright Vacuum Logo
102 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
