Question about Peg Perego John Deere Gator HPX Ride on Toy
How do you engage 2nd gear. only works in reverse and 1st gear.
    Scholar:
  • 110 Answers
Is the limiting screw still in the gearbox? just remove it and it should shift right into 2nd gear.
good luck!
Posted on Jan 28, 2011
Why won't my Clio automatic engagew 4th gear
How many miles? Have you ever serviced the transmission? f so and recently could be your throttle positioning sensor
Aug 28, 2014 | Cars & Trucks
Car won't engage any gear but reverse.
lincage rod inside the gear box will have bent it happens when to much preasure is applied commen for jamming up thow.
Apr 11, 2010 | 1992 Honda Accord
Have 1st 2nd and reverse, no drive 1988 model 2 wd
sounds like 3rd gear clutch is out (it might have blew out a lip seal or something)
pull the pan c if there is a lot of black on the bottom of pan (no 3rd = no 4th either) the 3rd gear clutches are engaged along with the 4th gear clutches to make overdrive
if the tcc cable is out of adjustment it mite shift at wot (wide open throttle) max rpm (5000-5500)
if it just 1,2, neutral its probly clutches
Mar 25, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Only reverse works. No foward gears.
No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
Do you have manual 1st? If so, can you shift through the gears...i.e. manual 1st to manual 2nd then 'D' then 'OD'??? Only 1st and 2nd gears use the forward sprag unless the LO/Rev clutch is engaged...i.e. 1st and 2nd if in "drive". If you can shift threw the gears manually then, yes, your forward sprag broke.
If no manual 1st then your sprag is not what broke. Sounds like you blew up the rear planet. If you pull the pan and find chunks of iron and steel, then that is probably what happened. If you have reverse then it is not the pump. If the pump was bad you would have no line pressure and it would slip in rev. or no rev. Not the beef sun shell either because you have rev., a broken sun shell would cause no 2nd, 4th and rev. gears. Either way the trans needs to come out and torn down and it will be easily found what went. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1991 GMC C1500
1988 wrangler goes foward but not in reverse. It won't engage in reverse. 1st, 3rd, 4th are great 2nd winding sound. what needs to be fixed or replaced?
it sounds like you have 2 bad gears, 2nd gear may be fine for an hour or for ten years, theres no telling on that. your reverse gear is probably shelled out. your best bet is to rebould your transmission or buy a new one, sorry
Nov 06, 2009 | 1988 Jeep Wrangler
Will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Jun 28, 2009 | National Little Tikes Hummer Yellow
Won't come out of 4 low and won't change from 1st to 2nd gear
try checking your auto trani fluid... and with the 4 wheel drive try puting ti in nuteral and if the doesnt work try puting it in reverse and back up after taking it out of 4 wheel drive.
May 24, 2009 | 1996 Ford Bronco
I lost my third gear
It seems in the manual transmissions the first gear to go is 3rd gear..
signs of a failing trans
Dec 08, 2008 | 2002 Dodge Neon
Peg Perego John Deere Gator HPX Ride on Toy Logo
116 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
