Hi i have a msi 790fx and i just upgrade my system to a a higher system but now my problem is the motherboard power pin has issues like when u pushed it down the system will turn on and when u release it.it will turn off.what is it? how can it solve?
Display on motherboard reads FF
THat is the "power on and first initialize CPU" halt code. Most often, if this error occurs, you have a bad CPU. You should also check the JBAT1 jumper to be sure it is installed and on the correct pins. If the CMOS is being held reset or does not have its power source the system cannnot initialize the CPU.
Dec 31, 2011 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
How can I find power supply replacement now that is compatible with 661FM-L BOARD?
Your motherboard uses a standard ATX power supply 20 pin power connector. Most ATX power
supplies should be compatible with your board..get a supply rated at 450 watts or higher for
future expansion of your system
Feb 08, 2011 | MSI : 661FM-L P4 SIS661FX FSB800...
I have an Asus 790GX G65 and when I boot
What that means, is that it cannot find a device that has an operating system on it i.e. a boot track.
Mar 30, 2010 | ASUS Crosshair III Formula AM3 AMD 790FX...
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the connections. When we turn on the computer all the fans start and all the...
check the cable connections initially
Remove the power cord from the cpu
Remove the cmos battery and reset the bios by changing the jumper which is present to reset bios in motherboard.
Place the jumper as if it was present already
Insert cmos battery and switch on the computer
Mar 04, 2010 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
I am looking to upgrade memory on an MSI N1996 Mother Board which has 2x 168 pin slots and 2x 184 pin slots. I wish to know if I can go to 2GB and which memory is best to use, i.e. ECC,...
If your motherboard supports ECC, and you can afford the much-higher cost of ECC RAM, then buying/using ECC is "best".
Note that "buffered" memory is much slower than "unbuffered" memory.
Nov 05, 2009 | Intel Motherboard
No video from the graphics card and code FF on the
Have you tested the card in another machine? If the card works in another machine, the motherboard might not be compatible with the card... If the card also does not work on the 2nd machine, then it should be a fault on the card...
If the card did work in the past, and it didn't burnt or damaged, you might get it working by cleaning it with a suitable cleaner like alcohol or spirits...
Regards,
Johan
Aug 20, 2009 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
