Question about Watches
Brand new women's Technomarine Neo Classic Chrono watch. Got the time and date set OK but the second hand is not moving. Sometimes when pushing button "A" (2:00 position) or button "B" (4:00 position) the second hand quivers as if it wants to move, but doesn't. Also the crown was originally flush with mounting, but after uscrewing it to get it to pull out to set the time and date, now it will not go back in all the way. Also cannot figure out what the other three little dials on the watch face are supposed to do - when I pull out the crown to set the time or date the little dials flip around randomly. The instructions that came with the watch are practically non-existent - they spend 10 times more space explaining why it's a bad idea to get your watch immersed in salt water than in explaining the features/functions. Thanks
  • katelavery52 Jan 02, 2011
    Thanks, the second hand never did start working. Since it is new I think I will do as you suggest and just send it back. Thanks very much for the advice - wanted to be sure there wasn't some trick to getting the second hand going.
  • 3,083 Answers
Sounds like there's a problem with the second hand, or gear that drives it. Best thing you can do is to take it into a Watch repair shop, and have them take a look at it. They will be able to ascertain what's going on, and see if the crown is stripped or broken..
Since it's new, I would just get an exchange, or store credit- it would cost too much to fix.
Good luck, and hope this helps.
Posted on Jan 02, 2011
Adjusting hands to markers
What you need to do is to pull the crown to step 2 (full out) and then push the chrono top chrono button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero. then push crown back in,, That's it.
Feb 18, 2014 | Swiss Army Maverick GS Chrono Mens Watch...
My wenger sport elegance chronograph watch stopped working after 2 months. I bought it brand new. After readjusting the time, it worked for about 8 more hours, and then died again. The small dial on the...
You should change the battery, it is the cheapest thing to try. The batteries can be very old before they are installed and could have been in the watch a long time before you got it.
Sep 30, 2013 | Wenger Sport Elegance Chrono White Dial...
Just bought the watch, I set the time but the clock is not running. does it come with a battery? should I return it?
kindly check the lower sub dial if it is working. if yes, you don't have to worry because it is a chronograph. if not, check the crown if it is pushed down, if not, you got to push it, and if nothing happens you have to bring it back from the seller probably the problem is the battery. I hope i had been helped you.
Jul 27, 2011 | TechnoMarine NEO CLASSIC LADIES WATCH...
How do I get the second hand chronograph to move?
The upper push button starts chronometer when pushed once. Second push on the same push button stops it. Lower push button returns chrono hand to zero.
Feb 26, 2011 | DKNY -Dial Chronograph Watch for Women
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 11, 2010 | Guess Stainless Steel Chronograph Watch...
How do I set the time and date?
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
Dec 20, 2009 | Festina Chronograph 16162/1 watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Watches Logo
82 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
