Question about Brother IntelliFAX 4100 Laser Fax
The printer keeps saying check paper - re load
Intellifax 4100
  • mgill109 Sep 23, 2008
    Where does the sensor go? I purchased this fax machine used and the sensor was laying on top of the paper tray. I can't figure out how it attaches.
    Thanks!
  • 550 Answers
Check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Posted on Jul 19, 2008
We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
Mar 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Our brother intellifax 4100 does not pick up the paper. Is there a protocol to follow and or a repair kit etc??
make sure paper stopper in cassette is not pressed too tightly against the paper. common problem on these models. best to leave an 1/8" gap.
hth,
razors
Dec 08, 2008 | Brother IntelliFAX 4100 Laser Fax
The machine says it has a paper jam
Please check your sensor if they have dust or paper?
Clean your Sensor if working properly.
Sep 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 skips
check the paper size settings, that it is set to the same size as the actual paper
~50% chance of being a solution, cant do better
Jun 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jam
Check your printer first, restart your pc and then try to print. If the message is paper jam again. Try to reinstall the software, if doest work properly the problem is your printer.
Jun 18, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 2440C printer not printing
could u pls elaborate the problem
1. do u have sufficient print cartridge?
2. paper is fed correctly (no jam)
3. printer driver is installed properly?
4. No conflict between drivers among the resources for the printer?
have a nice day
bye
I hope my solution was useful
Feb 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Brothers intellifax 4100
cassette is in front, put hand on bottom front of machine and pull, check to see if it is set to letter ( is the paper adjuster the part that can slide back and forth set to letter is there a switch in the cassette for custom and letter size? is it set to letter?
Dec 06, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
351 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
