Question about Hotpoint Washing Machines
My machine over flows when filling up - Hotpoint Washing Machines
  • 5,911 Answers
This problem is usually attributed to a pressure switch problem. The pressure switch is located under the operator console behind the load size or water level knob. This controls the fill level of the wash tub and shuts off the water inlet valve when it reaches the appropriate level. The pressure switch usually has an electrical connection and a small air hose attached to it. In some cases you may not have a defective switch at all. The air hose can come loose and fall off, or develop air leaks. Check the air hose to ensure it is properly connected to the pressure switch. If it is not, it can easily be reconnected. To prevent it from slipping off again, place a small zip tie around the hose at the point where it connects to the switch. DO NOT over-tighten as you may damage the small pressure switch fitting. Just make it snug enough to keep the hose from slipping off. If the hose is still attached, check the entire length of hose from the switch to where it connects to the wash tub for any splits, cracks, or holes. If you do not have an air hose problem, check the electrical connections to make sure the connector tabs are not corroded and you do not have any broken wires. If you have checked all the preliminary items, and still have problems, replace your pressure switch. If you post back with your complete model number it would help in providing part numbers if needed. I hope this helps you.
Posted on Jul 09, 2008
F&P GW512 Will not stop filling
If the water continues to flow into the washer with power removed from the washer, ie; unplugging it, then the water valve is faulty.
Jun 25, 2016 | Washing Machines
My whirlpool washing machine wont stop filling with water after the wash cycle
your post is vauge
does it over flow
you mean it wont stop the rinse cycle
did you check it for a reset
do a factory reset
the machine will fill with water until the flow sensor and level has filled
so check and clean the machine
i find a couple of dishwasher cleaner tabs thru it first will clean all the flows and pipes and use a 60 deg long wash for whites
i think all the electro is aok so must be dirt
Sep 24, 2014 | Whirlpool Washing Machines
Filling of machine required
Did this problem exist before your fix? Make sure the hoses are the correct way around on the flow meter and check the wires are plugged on correctly. It is possible to offset the plug on some models.
Mar 13, 2014 | Krups XP7225 Espresso Machine
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Over flowing washer
If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
