Question about Acer Aspire 5735 Notebook
When I power up my laptop the hard drive stops after a few seconds and the machine turns itself off. Anybody any ideas please
  • sussexsmoker Jan 01, 2011
    have tried using another ac adaptor , which is known to be good, with the same result
    Brigadier General:
  • 8,909 Answers
I would check you ac adapter as if it is not charging properly there will not be enough energy to carry on booting.
Hope that helps.
Posted on Jan 01, 2011
Testimonial: "good answer"
  • 72 Answers
Change your battary
Posted on Jan 02, 2011
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
The fan of my sony vaio model pcg 3c2l stops
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | Sony VAIO Notebook
1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
I have a Dell Latitude D500, The problem however, is that a times, the laptop will not turn on (power on), instead it will go into a power-on / power-off cycles. It will stay on for few seconds and then...
hi
please insert the windows boot disk and enter in the bios ..select booting option for cd drive...........
..............most probably you may have to reinstall....
if failed the problem may be with the display settings ...it is better to approach an expert or service center ........display settings options are in bios and an expert can only slove it......
thank you
hope you do it soon.......
Oct 29, 2009 | Dell Latitude D600 Notebook
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
A Frozen 2008 Macbook Air
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
Mar 08, 2009 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
Startup problem ibm thinkpad t43
Are there any status lights on? What are the circumstances that led to this issue? and Lastly, describe the climate you use the laptop and how long you use it during any normal period of time?
I ask these questions because I have a clue to what your problem is.
Nov 16, 2008 | Computers & Internet
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Acer Aspire 5735 Notebook Logo
244 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
