Question about Apple iPod nano
Ipod i pluged it in to the computer and it is stuck on the DO NOT DISSCONECT screen
That has happened to mine before and it toook me forever!! to figure out what to do.
1.) disconnect it from the computer from itunes and safely remove hardware at the bottom right of your computer
2.) toggle the hold switch back and forth so that it is o hold then not again
3.) put the ipod on a flat surface and hold the menu and centre button
4.) the apple symbol should appear and it should restart but still have all your songs and new songs still there
try this a couple times and if it doesn't work then i don't know
Posted on Jul 25, 2008
Me and my friend are takig turns using my other friends ipod and my friend forgot the passcode and tried to much, and nw it says connect to itunes. when we do it doesnt work and so we tried everything, we...
With the phone UN-PLUGED and powered OFF. Hold the home button and plug into a computer using I-tunes. Continue to hold till the restore screen starts on the computer. You will restore the device to factory and loose everything but it will be useable.
Feb 24, 2011 | Apple iPod touch
Ipod touch 64gb 3rd generation is stuck on, It is stuck on a screen and will not do anything.
hold down your home key and your power key for about thirty secinds with it pluged in to you r cpu thn release your home key only until something happens i kinda forgot becaus eits been a while but it should say something like restore mode on your cpu itunes screen or you can take the battery out just look up how to do it on you tube
Jan 25, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Frozen ipod
You just need to reset it, hold down the middle button and the "Menu" button for about 7-10 seconds, or until you see the Apple logo.
Hope this helps.
Oct 20, 2009 | Apple iPod nano 3rd Generation
My ipod screen turned white please help
Try doing a full restore by putting the ipod into recovery mode. Make sure to set it up as a new iPod and not use a backup.
Oct 06, 2009 | Apple iPod touch
Ipod touch wont turn on unless pluged into computer
Itmaybe a battery problem...if you think its not a battery problem,you may want to try a software upgrade/restore...if your software version is already the latest one,backup all the ipod contents before you will find the restore option in the summary tab in itunes.
Sep 27, 2009 | Apple iPod nano
My ipod touch turns on and shows the apple sign and cuts right back off i pluged it up and it did the same thing and i went to i tunes and pluged it up and same thing happend
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced. If you replaced your battery and this still happens, then your logic board has gone bad.
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
My Ipod 3rd gen. wont work other than when its pluged into the pc
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Aug 05, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
Ipod wont recognize it's been disconnected from the computer
try reseting the ipod it should tell you how in the manual
Jan 21, 2009 | Apple iPod nano MP3 Player
Ipod 30gb black
Hold down the middle and menu buttons at the same time for about 10 seconds. this will restart the ipod.
hope this helps and good lcuk!
Oct 03, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 20g
hi.. if you have itunes, run the program, connect the ipod to it and then see what it does.. i would suggest just using the restore option in itunes so it can reset your ipod.. u can only do this on itunes but i've also found that realplayer will work with itunes as well so hopefully one of those two programs will work for you.. itunes is a little glitchy with windows vista so keep that in mind if you are running a vista os.. you can also go to your start button, click and open the MY COMPUTER option and then see if you can see see your ipod plugged in--that is another way if you don't see a prompt pop up after you plug it in...
let me know if this helps, if not, i can still do more troubleshooting.. be sure you have enough memory if you haven't installed itunes yet.. good luck.. d
Feb 23, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod nano Logo
20 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
