Question about Nokia N900 Smartphone
My nokia n900 device memory is corupted - Nokia N900 Smartphone
  • Ismail M Jan 01, 2011
    Please provide full details of your problem.
    Sergeant:
  • 298 Answers
Whenever you receive a message saying the memory card is corrupted, this means that there is a virus or some sort of dangerous file which is trying to or disfigure your phone system.
Normally there are two ways to go about this problem, one of which is to make a complete back-up of all your files and then do a format of the memory stick or of the phone memory depending on which memory is corrupted.
Also, you can connect it to your computer if it is the memory card and then use a good anti-virus to scan your memory card, normally if it is a virus it should eliminate the virus while scanning.
Lastly, if the message is from your phone memory, then the only available option is to flash the phone memory and this requires expertise and should be sent to a repairer.
hope this solved your problem?
Posted on Jan 01, 2011
How to clean rootfs in nokia n900 ?
use purge for installed apps. And dpkg -l ' grep ^rc (this command will show you a list of apps configuration files still left in the system from uninstalled app)
dpkg --purge <appname> (This will remove it)
Performance Chip
May 22, 2012 | Nokia N900 Smartphone
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
My wont open. the NOKIA logo screen there was written
if u use extra memory the try to open without memory if face again smae problem the hard reset this device using some key combination but all data distroy key combination search on google with exact nokia model
May 16, 2012 | Nokia N900 Smartphone
Download nimbuzz in nokia n900
Hi you can download Nimbuzz from the Ovi store on your phone, Or you can go into settings, connectivity, USB and select Nokia Suite as default.
Plug your N900 into a laptop or pc via usb and you will be prompted to install.
Easiest way is through Nokia's Ovi store. If you dont have the store client on your N900 here is a link for Nimbuzz, Ebuddy etc
http://en.softonic.com/s/nimbuzz:phones/device-nokia-n900-1224
Hope this helps
Mar 05, 2012 | Nokia N900 Smartphone
My nokia n900 does not show internal 32gb memory and shows memory card corrupted.i had tried through nokia care they did flashing.even clear my device through setting but problem not sorted out.please...
hi,
I had the same problem. Just format the memory FAT32 using Windows... that is not a joke!... just try it...the 32MB memory acts as an external (card) memory thus can be formated using Windows... obviously the info on the memory will be lost unless you have a backup file...
Feb 26, 2011 | Nokia N900 Smartphone
It refuses to boot completely after going off and reads system malfunction
This can be caused by number of reasons:
  • switched off the device or battery was removed in the middle of a system update
  • tampering with the system software (Maemo5) or SIM lock protection
  • defective memory or other component fried
  • water or dirt inside the device or external connectors
The N900 is targeted at computer nerds (I have one, too :-), so given expert knowledge on mobile devices and the intrinsics of the Maemo operating system it is running you can actually do a lot of modifications and repairs yourself, including completely re-programming the device from scratch. Nothing for the faint-hearted, though.
However, I recommend contacting a Nokia service station for fixing your phone. To my experience, if no spare parts are required, they ask very reasonable fees for repairs and since the N900 is relatively new still, you might be eligible for a warranty covered fix.
Dec 27, 2010 | Nokia N900 Smartphone
My new nokia n900 phone tells me memory full, delete data to free memory but i have 26 G memory available. because of this it can nnot save messages and other files. what can possibly be the problem please
Back up all your data and file(s), example your contact and messages. Install Nokia PC Suite latest version from the website nokia. By installing nokia pc suite you can open your phone memory card and memory card to save it to your computer. After saving your contacts, messages and other files it is time to format your nokia n900 using nokia pc suite. Then test you phone.
Nov 13, 2010 | Nokia N900 Smartphone
Problem nokia n900 memory card handfon 32gb corrupted
the nokia N900 does not accept memory cards over 16gb
Jun 30, 2010 | Nokia N900 Smartphone
My N900 has no memory even though 32GB are free
the memory in use will be of phone memory. make sure that you have selected both the phone memory and memory card to store things....
Apr 07, 2010 | Nokia N900 Smartphone
No phone memory problem
ya i have one code for format ur mobile device. you'll try it and hope it 'll work. the code is*#7370#.
Mar 07, 2008 | Nokia 6233 Cellular Phone
Nokia N900  Smartphone Logo
148 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
