Question about Acer Computers & Internet
I have no driver registered on the laptop for a cd dvd rom was there before not there now looks like it has been removed and do not have a disc to reinstall this driver
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Jan 01, 2011
Which drive on my satellite A 100 is the dvd or cd drive?
Your Drive : CD-RW/DVD-ROM COMBO DRIVE
This CD-RW/DVD-ROM drive is designed to read DVD-ROM discs as well as CD-ROM, CD-R, DVD-RAM discs
Oct 10, 2012 | Toshiba Satellite A100-S8111TD Notebook
Cd-rom ate dvd disc
In most cases the screw is on the bottom, flip laptop over, there should be one or two screws located in that square, remove them, "sometimes a button release" open tray door and pull out until driver slides right out.
Apr 25, 2012 | ASUS 15.6 AMD C60 3GB RAM 320GB Hard Drive...
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Have inserted a disc. can not open disc tray to remove disc
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 27, 2011 | Computers & Internet
I have a toshiba satellite A laptop,it use to play DVD movies and now only plays music CD's. What can i do?
You have a software problem not a hardware issue. You will find that the register may need repairing. ( Run Mechanic program in Win xx ) or to put it simply the computer forgot it has a DVD/CD you should go into control panel revome the CD drivers in uninstall or add/remove hardware. Then reboot and let Win detect new hardware as the DVD/CD let it find the drivers over the net or if you know the infoof the DVD/CD 'select from list' to add manually. Chances are though you don't have a driver disk nor would it be able to read it because you will have disabled the malfunctioning driver so it must come from the inter net or change the boot sequence in the 'set-up' to cd rom first and put the original Win disc in the CD and reboot.
Happy movie'ing! < not a word, yet.
Good Luck. Let me know.
ash
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Where is the CD drive on the Dell studio laptop need to put in disc for printer
you can see a slot on the right side of the laptop. you need to put cd in to that. you cannot see any CD Drive coming out of this model. Its a slot CD/DVD reader. So jst push the CD in to the slot. it will start palying. to eject go to my computer and right click on CD driver and click on eject. thats it ok
Jan 19, 2010 | Dell Studio 15 Laptop
Boot
what disc your using to boot?
just leave bootable disc in the dvd drive such as OS and drivers dell disc.
power off then on the laptop keep tap on F12 then select onboard CD/DVD ROM then press enter then tap space bar.
if still not reading any disc then have you dvd drive replace.
Dec 06, 2009 | Dell Computers & Internet
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
