Question about Samsung Digimax S730 Digital Camera
My camera lens do not come out ,and it makes a beep sound then the camera turn off by itself
    Guru:
  • 441 Answers
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Posted on Jan 05, 2011
Dropped Samsung S630 digital camera. Lens was extended and after hitting hardwood floor became bent. Is bent slightly and stuck in out position. Camera makes 3 loud beeps when powered on and immediately...
This exact thing happened to me. The 3 load beeps is the camera warning that the lens has not been collapsed. Unfortunately in these little cameras everything is so tightly fitted and assembled that your best bet is to either replace the entire lens assembly or the camera itself. A quick search on eBay turned up no results for replacements parts so unless you have warranty, you may need to replace the camera. :(
Feb 01, 2018 | Cameras
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
My camera keeps turning off with a full battery and makes a beeping noise
There is something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Apr 30, 2010 | Samsung L100 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Samsung S760 wont turn on properly - beeps twice lens comes out n in, then goes off n beeps again
it may be a lens error. mine does that all the time. make sure you remove the batteries or make sure it can't turn on while it is in a jam packed place like a purse or the case for it because the lens could get jammed. it sounds like that's what your problem is.
May 28, 2009 | Samsung S760 Digital Camera
Digimax A7: When I turn it on it turns off.
It seems i have the same problem...although my batteries do charge, and i can take pictures. But when I play them back It does this beep beep beep and shuts off and the lens doesnt always close. It's really pissing me off
Dec 20, 2007 | Samsung Digimax A7 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Lenc cover will not open
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 12, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S730 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
