Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
I'm trying to link my laptop to my hannspree monitor to view a dvd. how is this done?
  • 696 Answers
The exact process varies by make and model of your laptop, I will give you the "generic" hookup instructions, if you get stuck at any point simply reply back with the make and model of your laptop and the exact model # of the Hannspree and I can give you more specific instructions.
First you need to identify which video out ports you have on the laptop, most current models have VGA which has 15 pins in three rows of five, these carry video only. Many current models also have HDMI outputs which can carry audio and video. Now check the Hannspree and see which options it has. Identify one of the port types which is available on both the laptop and the monitor.
Once you've identified which ports will work hook up a cable between them and turn on the monitor. As far as I'm aware the Hannspree should switch to the chosen input so long as nothing else is hooked to the monitor. Now look at the bottom left portion of your keyboard, there should be an "Fn" key. This works like a Shift key only it activates the pictographs on some of your keys. Depending on the brand the "Fn" key can be one of many colours.
Whatever colour it is, look through the pictures on your F-Keys(the top row), depending on brand you should see , "crt/lcd" a picture of 2 monitors or a single box with a line on either side. Hold the Fn key down and while holding it, press the F-Key you found with one of the monitor symbols. Depending on the brand this will either cycle between laptop, external or both or it will bring a menu up on the laptop screen offering options.
Once you've set it to external or both monitors, if the hannspree isn't showing and image check the manual or reply back with the model number and I can help you figure out how to switch inputs on the monitor.
Hope this helps FixYa,
Chris
Posted on Jan 01, 2011
Manual hannspree hsg1138
I am finding this a bit difficult to locate. However, here is a link to a manual for a similar model. http://www.hannspree.eu/uploads/Downloads/Monitors/HannsG/HL/HL225DBB/UserManual_HL225D_EN_V1.0.pdf
Aug 20, 2015 | Hannspree 19" Widescreen LCD Flat Panel...
Hannspree monitor hsg1067 schematic
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 10, 2014 | Computers & Internet
My Hannspree HF199H monitor developed a distinct reddish hue a few weeks ago, I returned it to Hannspree, who sent it back saying it was fixed, but problem remains. Haven't found a website with Mac driver...
Have YOU tried attaching this monitor to another pc, or laptop to check if it is faulty, it may be a fault on your computer.
If it is still faulty on other machines, get back in touch with the manufaturer.
Jul 26, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
How do i connect my Hannspree 22" monitor to my Dell Inspiron 1150 Laptop?
On the back of your laptop there is a vga connector, to the left are two(2) usb connectors and the right is your network connector . You need a vga cord (if you bought the monitor new it should include one.) Plug the cord into this port and into the back of the monitor. Plug the monitor in and the laptop should recognize thatthere is an external monitor connected and switch the video output to that monitor.
Take Care
Cammi
Nov 26, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Monitor
Right click on your Desktop (depending on what OS your using) and go to properties! Click, on the TAB that shows monitor. See if any info is available, any problemd, email me!
Apr 06, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Can a macbook pro work with a hannspree 28" LCD monitor?
I cant see why not, On you TV you have incomming port called HDMI, on your mac you have an outgoing port called MiniDislay for DVI.
You can use that port whit an adapter to make it to a real DVI, the you need another adapter to reform the DVI to HDMI. It can be done, its a little bit tricky, but it can be done.
here is the spec on your mac
http://www.apple.com/macbookpro/specs.html
And here are the spec for yor tv
http://shopper.cnet.com/lcd-monitors/hannspree-hf289hjb-flat-panel/4014-3174_9-32915918.html#info-5
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
124 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
