Question about Vacuums
The fan blades under the motor are broken i like my dirt devil triangle please help fix it.
Generic problem for all Vacuums
Posted by roadrunner19 on Jul 08, 2008
The fan blades under the motor are broken I like my dirt devil triangle please help fix it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Changing the fan should not be a problem; it happens every so often if you pickup something big and the plastic fan breaks. The cost to repair is about $10.00 to $20.00 plus labor and you can repair it yourself if you are handy or take it to a local vacuum cleaner dealer in your area and they can perform the fan replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
Dirt devil easy lite. I vacuumed up a coin I think, the vacuum is now screaming.. How do I remove whatever it was that got vacuumed up?
The coin may have broken the fan. You will need to inspect it to see if the coin may have gotten stuck somewhere causing the noise. Inspect the fan for damage.
Feb 18, 2015 | Dirt Devil Easy Lite Quick Vacuum
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
I have a Dirt Devil Jaguar bagless vacuum. It used to work great. Now, it is blowing a huge amount of dust out of the front of the machine as I try to vacuum the carpet. can this be remedied?
This generally happens if the hose system is clogged. No suction so the power head brush just kicks out the dirt and debris you're trying to pick up, and loose stuff that is currently in the hose system. If it has been doing this for quite a while, or has been used with blockage, the motor has to work harder and will eventually burn out, if there is no overheat shut of switch in the cleaner.
Check all parts of the hose system, from the power head to the tank. Clear all clogs. That should take care of the problem.
Another possibility is that the fan blades are broken or worn down. This would result in no suction even though the motor is running.
Dec 09, 2010 | Dirt Devil Vacuums
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
