Question about Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged
Need the wiring diagram for capacitors on a IR model 2475N7.5
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Posted on Oct 23, 2009
  • 1274 Answers
SOURCE: All three of my capacitors blew in my IR T30. I
Hi, my name is John. Welcome to FixYa. Both of the black wires go to the + side on each capacitors, and the white wires go to the - side of the capacitors. Thanks For choosing FixYa...John
Posted on Dec 03, 2010
Do you have wiring diagram for the capacitors
Why are you replaceing capacitors? If they are "shot" put new back just the way the old were. Mark wires before you remove old. If capacitors are missing I understand the problem. Since you didn't indicate a model, you may find a service manual with wiring diagram here:
http://www.manualslib.com/
Mar 11, 2015 | Heating & Cooling
Capacitor Wiring
I would think you have solvrd this by now but anyway I needed your model number of the unit outside more than the capacitor. Here is a simple diagram.so try to go by location and your colors. Should you have questions I will be here, Thanks Sea Breeze
More Carrier AC Wiring Diagrams
Jun 14, 2013 | Heating & Cooling
IR MODEL 2475 COMPRESSOR 7.5 HP, MOTOR WILL NOT START COMPRESSOR AND HUMS, CAN TURN PUMP AND MOTOR BY HAND, MOTOR WILL START SLOWLY WITH DRIVE BELT DISCONNECTED
The WEG 7.5 hp motors often blow the start capacitors. The box on top of the motor has 4 caps in it. 2 start and 2 run caps. Mark the cap wiring or make you a diagram to have at replacement time. Remove one or both of the caps. It is easier to remove two wires and pull the start caps out as a set. They are the black, large ones. I think they are 286 Micro farad caps. To get identical caps you may have to order from IR. If you can find a WEG motor shop they may have them. I usually go to grainger or my local motor shop to purchase. The ones here will be larger in size but can be fitted into the box on the motor. Also inspect the wiring in the box. I have found some wires with insulation gone. This may have caused your problem or a problem latter down the road.
Aug 31, 2011 | Ingersoll Rand Air Tools & Compressors
Wiring diagram for IR COLOR CAMERA MODEL IR-923B
There are companies that will expedite your passport application within 24 hours. It will cost you more but maybe it might be worth it to you. stewbison
Aug 16, 2011 | Optics
All three of my capacitors blew in my IR T30. I failed to diagram the wiring. There are two start capacitors and one run cap. There are two white and two black wires from the motor. Does anyone know...
Nov 29, 2010 | Ingersoll Rand - Rand Type - 30...
Wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Apr 01, 2010 | Heating & Cooling
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Start Capacitor wiring diagram needed
When hooking up capacitor on a pump it doesnt really matter which way the wires go. The capacitor is set up in such a way the it supplys power wherever the wires are hooked up. I hope this helps
Jun 02, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged Logo
520 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
