Question about Zanussi 32 in. DE6755 Dishwasher
MODEL DE6755 AQUAPULSE MACHINE TURNS ON AND THEN THE BRUSH AND WHAT APPEAR TO BE A HOT PLATE LIGHTS FLASH REPEATEDLY IT ALSO SOUND LIKE IT IS TRYING TO PUMP
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
I have a brand new shark navigator. It is smelling like it is burning and the bottom is so hot that you cannot touch it. It makes a sound like a bearing went out like a jet engine sound. I love this...
It looks like the rotatin brush is stucked. This brush is actioned by a ruber belt. If the brush is stucked then the motor axel is sliding on it and gets hot. From here is comming the smell. Ceck the brush and find out what is keep it stuck. More than sure there is a shoelace. Remove it and enjoy your machine.
Jan 26, 2011 | Vacuums
My on vacume it on juice on carpet and now it is not turning on
Remove the bottom plate under the vacuum and check the brush assembly for being stuck. Remove the belt from the motor and try to start the machine--does the motor spin and have vacuum? This machine is not a wet-pickup type vacuum. If the motor now runs, remove the brush assembly and remove the end bearings. Clean the brush in hot water and dry off. Clean the outer bearing interiors with a Q tip swab wet with hot water, then another to dry them out. Use a third to apply a small amount of light machine oil (3in1, or sewing machine oil) to the brush ends and the bearing interiors. Reinstall the belt and turn the machine on--hopefully, this will get it working again. Good luck!
Jun 10, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Continuous draining - unable to reset - all lights on
Cut power for minutes, and see if this can stop and reset the machine.
If the machine does not reset, then you need to test the pump and valve solenoid, to ensure it is not stuck on drain position, by energizing the solenoid.
If the pump solenoid is fine, and pump opens and close, then the problem is usually the control panel, rarely can also be a contact on wiring harness to the pump.
Eneter model number here to find parts and diagrams for your appliance.
Here also parts and repair help.
Feb 26, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Zanussi DE6755
This is for the right model, but is the UK version, all should be the same but power supply details might differ if you are in US etc. http://www.serviceforce.co.uk/pdfs/U23297.pdf Hope this helps :)
Mar 05, 2007 | Zanussi 32 in. DE6755 Dishwasher
Zanussi 32 in. DE6755 Dishwasher Logo
89 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
