Question about Microwave Ovens
The door of the soap dispenser opens but the soap is unused
    Brigadier General:
  • 8,909 Answers
The description is interesting as I have never heard of a microwave oven with a soap dispenser.
Please resend your question and include make and model.
Thank you
Posted on Jan 01, 2011
EGGS SPLATTERED INTO MICROWAVE EMA301D2PS ELECTROLUX; HOW TO CLEAN IT?
Put a bowl of water with a couple of slices of lemon in it. Put it on low power (no convection) and heat the water up to a simmer. Turn off the microwave and leave the door closed for 10 minutes. Open the door and clean with dish soap and water, or for tough marks something like Comet or Mr Muscle Kitchen cleaner as all the dirt will be soft.
Dec 23, 2015 | In Microwave Ovens
Westpoint manuals
I've never had a microwave oven that dispensed soap. Are you sure you posted this in the correct area? Also, manufacturer, make, and model number would be helpful when you do repost.
Jun 08, 2014 | Microwave Ovens
We stopped getting water from our Kenmore freezer door dispenser. I have verified the solenoid valve is working. The line from the solenoid outlet to the dispenser appears to be plugged (can't blow...
Many times the lines get frozen as they run through the back of the refrigerator section. Sometimes simply turning the temp up in that section will open the lines. Additonally, you might have to remove everything from the unit and totally defrost it to clear it. IF it's Ice.
Do you use a filter for the water comming into the unit? IF not you could have a blockage. If that is the case you will have to find where the block is and remove the block.
Jul 23, 2011 | Microwave Ovens
How do you prime a soap dispenser pump
If soap is not pumping than you have a hole or crack somewhere in the pump's chassis or straw.
Jun 27, 2011 | Microwave Ovens
Automatic ice cube dispenser will not dispense cubes, will not rotate
Do you hear the motor run when you "dispense" (door has to be closed)? If so, take the dispenser out and look for broken parts (seems like normal).
May 20, 2011 | Microwave Ovens
Where is the rinse aid on a dishwasher?
It is located in the inside of the dishwasher. On kenmore /whirlpool/frigidaire/galax
there is a roundknob located in the soap dispenser box which you turn counter clockwise
and pull out.
this is where the rinse aid is poured in. There usually is a small window to see it.
On hotpoint, kenmore there is a large knob inside the door (usually grey) it turns counter
clockwise and pulls out.
hope this helps.
Mar 02, 2011 | Microwave Ovens
Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
Jan 07, 2011 | Microwave Ovens
LG refrigerator model #LRFD25850TT water dispenser no longer working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. Or use a hairdryer on the inside of the door below the dispenser.
Dec 26, 2010 | Microwave Ovens
How to clean
The only good way to clean is with a warm wet rag and a bit of dish soap....then after cleaning make sure to leave the door open and allow the inside to dry out before using...
Wish there was an easier way but unfortunately not...
heatman101
Sep 15, 2010 | Microwave Ovens
After the soap dispenses, there is a buzzing noise but no water seems to be spraing
sounds like the water valve . ck it for rust of hard water build up as if the water can't get through it it will not fill . water should be up to the element . or about 2 1/2 gal .. if water is not in tank add some and se if it works then ck the float to make sure its ok. the buzzing could be the motor hum . **** hope these hepled to find the problem .. **** .
Jan 04, 2010 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
