Question about Dishwashers
Constantly going into an "unbalanced
    Novelist:
  • 222 Answers
Need to replace the support drum of your unit,the coz of this one why its wort out is overload every time you use,put exact amount of kilo in dryer for long last use,now the support drum is not easy to remove only the service technician can do that coz we need to dismantle the unit to replace that part. i dont know how much the price.again dont try to repair this one coz is hard,
Posted on Jan 01, 2011
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
What is amount of water top loader use?
Just enough water to cover the clothes. As the clothes get wet, they will settle. The least amount of water needed to do the job will also save the amount of expensive laundry detergent. So regardless of the wash size setting, watch it and go to the next part of the cycle manually to avoid more water, and hence, more detergent needed. Only put enough detergent to make the water slippery, and no more. You can tell this by simply feeling the water and rubbing your thumb and fingers together.
Jul 13, 2014 | Admiral AW22 Top Load Washer
My washer always gets unbalanced load with 7 minutes remaining.
This sounds like a problem with an unbalanced washer or unbalanced load. Your washer has four leveling rubber screws underneath. To keep it from rocking make sure all four points are touching the floor at all times. Washer machine being level is a great plus. Also it could be the amount of clothes put into the washer. The more clothes you put in the less chance of your load being uneven.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Always unbalanced in the spin cycles
the machine may need to be releveled, if it is not level the clothes will have a tendancy to go to the low side and thereby causing the unbalanced condition
Mar 20, 2011 | Haier XQBM22-C Top Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
Laundry too wrinkled
grabbed this of an official whirlpool web site: Clothing in the washer can become tangled and twisted or balled up.
Under certain conditions, a combination of the wash load, the cycle selected and the subsequent load movement can cause
the load to become tangled or twisted.
The wash impeller has been redesigned to make the wash load less likely to tangle under the conditions mentioned above.
Replace the wash impeller with part #W10141017.
willing to bet your serial number is before this number here. easy enough part to switch if its no longer under warr
SERIAL CODE RANGE: Prior to CU39
Remove & destroy
pointer L8178694
dated September 2007
Oct 27, 2008 | Washing Machines
Excessive shaking during spin
hi thanks for the question is the washer on the main floor on a wooden floor if it is re level washer next pull washer towards you tipping towards you lift from floor a few inches and let drop to floor this will re level the back legs thanks the appliance doc
Mar 17, 2008 | GE Profile WPRE6100G Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
