Question about Music
There is current going through the organ hohner D89, and the buttons for other instruments work. The piano does not have any sound at all
5 Suggested Answers
  • 5603 Answers
SOURCE: hohner symphonie D98, no key board sound
Look for an exploded electrolytic capacitor. They amke a pretty loud bang and make a visible mess. CLEAN any residue when restoring.
Posted on Dec 31, 2009
  • 5603 Answers
SOURCE: Only the piano sound works on my D-20.
We can't possibly guess at what brand a D20 might be,,, HOWEVER let's guess that it is some kind of synth.
I would "guess" that you problem might be that the ionternal memory battery has depleted and the settings and sounds are all lost.
First thing would to be replace the battery. Next the settings need to be restored. SOME instruments have a sequence of buttons to hold while powering on to restore factory settings. Others require you to load data from an external source via MIDI or other method.
Posted on Feb 13, 2010
  • 5603 Answers
SOURCE: Is there a Yamaha school
Yamaha prefers to MAKE the instruments rather than conducting repair schools... they may have some very specialized schools for individual types when first introduced. With the situation in Japan right now such classes would be cancelled I am sure. Instrument repair is so specialized other than basic piano repair/tuning that you will find few if any courses. For piano repair you might want to search YouTube for videos. For organs and keyboards, detailed electronic knowledge and the service manuals are what we have to work with. You need both experience in digital and analog plus test equipment including oscilloscopes and signal generators as a start.
Posted on Apr 13, 2011
  • 5603 Answers
SOURCE: My Privia PX-3 will run
This problem is NOT DIY and will likely require a trip to the repair shop... One possibility is a static discharge... Try running it for hours with no clothes on that can produce a static buildup and see if it behaves. If so, take maeasures against static... no rubber soled shoes, no wool fabrics, gound yourself to something else before touching the unit...
Posted on Aug 16, 2011
My gulbransen organ stopped making sound.does it need a fuse?
Possibly, but a blown fuse is an indication of a larger problem. Ask your local piano/organ store what tech they use or go to this site-
Electronic Repair Services for the Entire Music Industry MITA International
Sep 30, 2015 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
At times during a performance the organ sounds drops significantly compared to the ensemble sounds, what could be the problem?
Has it always done that? It could be it just doesn't have enough power to play organ at full volume along side the ensemble.
May 25, 2015 | Roland VR-700 V-Combo 76 Key Stage Piano
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
Sep 24, 2014 | Yamaha P95 Digital Piano
My Privia PX-3 will run fine for about an hour. After that, for example, if I am playing a piano sound and want to switch to organ, I press the organ button and the LED shows that I have chosen the organ...
Aug 16, 2011 | Casio PX3 Privia 88Key Digital Stage Piano
Is there a Yamaha school of instrument repair? Pianos, Keyboards and Organs
Apr 13, 2011 | Yamaha Music
Only the piano sound works on my D-20. If i press a key in any other voice or instrument it just makes a high pitch sound and freezes up. And on the ''B'' bank its all organ sounds.
Feb 12, 2010 | Music
Hohner symphonie D98, no key board sound
Dec 31, 2009 | Hohner Music
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
