Question about Garden
Have al2306 airless paint sprayer replaced inlet outlet valves still no suction with new parts on
revancha
  • 190 Answers
SOURCE: Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
Posted on May 15, 2010
  • 700 Answers
SOURCE: I have a wagner airless
Yes, yo can repair it. there is compound problem with the unit. Please use this advice for future to save yourself time and money.
Before you store any painting equipment for longer than few days:
1. Strip equipment to base pieces,
2. Clean them with paint stripper
3. Wash them in water and then dry them through
4. Wash them in solvent, dry them, put vaseline on rubbing parts
5. Store in dust protecting rags or bags
You just used your gun without cleaning it, that was part of the problem, gqasket on the bottom of the piston was weakened by paint and two years of storage, you did not strain paint, you just used it directly from the can. chunky bit from the can (there are always bits forming around the toip and sides of the can) clogged piston, giving impression that there is no paint, you incresed the pressure and gasket give up on you...
Just follow advice, clean the gun, put it to pieces, find which gasket (I suspected that this one will be from the bottom of the piston), most of hardware stores have spares for these guns, buy exactly same dimension, put gun back together and this should solve your problem.
I do that sort of the "surgery" on the tble with several layers of old newspapers under and last laer butchers paper, I put my pieces in order in which i removed them so I can easy put them back together. Always strain paint, always clean gun...
Hope this will help solve your problem :-)
Posted on Aug 08, 2010
puertobori
  • 7733 Answers
SOURCE: I have bought a repair
Go to this LINK.
Posted on Oct 26, 2010
  • 250 Answers
SOURCE: I used this brand new
You have to take it apart and there is a ball check stuck open. Tap the ball with a wooden stick to free it up.
Posted on Mar 18, 2011
  • 885 Answers
SOURCE: Wagoner Procoat Airless Sprayer without
One cause for this is that one or both of the check balls in the piston are frozen in place. This can be caused by drying paint on the check balls or seats or, as is the case many times in our area, if you did clean the machine well with water without any airless conditioner in it, sometimes the water dries and leave behind minerals that 'lock' the check balls in the seats. Set the machine up in water and turn it on to prime. Using a hammer hit the pump head where the piston is working fairly hard. You are trying not to break anything but knock the check balls loose. If they come loose and water starts cycling through the system, let run a while to wash anything out before switching to paint. If this doesn't work, you may have to take the head apart to see why the check balls won't free up. It could be because of peices of dried paint that won't come loose by themselves.
Posted on Jun 16, 2011
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Will not pick up paint
Hi Dan,
Yes there is a second ball valve; it is the outlet valve located inside the piston. When you remove the inlet housing to access the inlet valve and its parts, you can partly inspect the outlet ball valve which you can see in the end of the piston; check that it is free to move and nothing is stuck in it. Another thing that can stop the sprayer from priming is the priming circuit is blocked up, either the bypass valve or the return hose or both. This happens when you don't flush this out at the end of the day.
Sep 16, 2014 | GRACO INC 210 ES Airless Sprayer
Graco paint sprayer repair
Odd that you have air coming out of the suction, however it sounds like your inlet valve is not closing, the ball damaged or missing, or the O-ring under the valve seat is missing or damaged.
Aug 14, 2014 | GRACO INC Ultra Max II 795 Electric...
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Pumps in up stroke but not in down stroke
Single stroking: You have something stuck in one of the valves, probably the inlet valve.
Sep 25, 2013 | Speeflo Titan PowrTwin 6900 Plus D.I....
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Where on the unit are the inlet valve and the push button valve?
On the front of the pump unit is a large aluminum block, the valves are inside that. The inlet valve is behind the fitting for the suction tube and the push button valve is the only one on the bottom of the block.
Dec 17, 2010 | Campbell Hausfeld Airless Spray Guns &...
Paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Can't find a part #
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
