Question about Onkyo TX-SV828THX Receiver
I have Onkyo TX-SV828THX Receiver, It automatically turns off by itself after may be 5-7 mins. What may be the problem? Please advise. Thanks for your help.
SOURCE: onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Posted on Nov 30, 2007
SOURCE: My Onkyo Receiver TX 601 is turning itself off
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Posted on Jul 30, 2008
hi-fi
  • 25 Answers
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 17 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
Receiver won't turn on unless u unplug for 5/10 min
Hi Bart, I would suggest that you try a hard reset as there might be a glitch in the processor, if you email me your model number I can advise you of the reset procedure. Please email me at askOnkyo@us.onkyo.com, Thanks, JT
Oct 18, 2015 | Onkyo Audio Players & Recorders
Hi,,My onkyo tx-sv828thx problem was it shows "protect" sometimes.then after 2 to 3 second its back to normal operation. What do you think the problem?can i do it by myself? anyway,i am using...
The protect message appears when the current powering an amplifier inside the receiver goes beyond the safety limit or the amplifiers overheat. So just check the wiring and the speakers impedance with an ohmmeter - each should be above 6 ohms
If they are lower then you have a short in one of the actual drivers of the Bose 901 speaker . If the impedance is OK then the Onkyo overheats, place it in a better position to increase the airflow thru it.
Sep 04, 2011 | Onkyo TX-SV828THX Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Onkyo tx-sv828thx
Audio amplifier IC damaged need to be replaced
Aug 30, 2009 | Onkyo TX-SV828THX Receiver
Onkyo tx sr804 receiver turns on by itself
I have the same receiver and the way to fix is simple. in the main board of this unit there are 5 connectors and they slide into other components like Lego. the issue is the king of material they are made of it's cheap. if you reseat the mainboard it will fix it for a day or two, them it will start again. the easyway is to re seat the board and put a fan inside of the receiver between the transformer and the inside of the amp pointing down about 20 degrees connect the fan to a ajustible voltage adapter and connect it to the outlet in the back of the unit. so it comes on when you turn it on. this voltage adapter is cheap. the adapters people buy for phones and or MP3's at Radio shack or Best buy it goes from 1.5v to 12 volts/ this way you can control how loud the fan is in side the receiver. i find 4.5V does the trick. The connectors on this board start to loose contact with some of the pins when heated. the fan keeps it cool enouth to fix the issue. I fixed manny these ONKYO 804's this will fix it. you just have to do it. the main board is inder the HDMI board in a Vertical position running from one side to almost the Power supply. it has 2 screws also holding it in the inside middle back of the amp. Becarefull with these amps 75 V at 23amp's DC is no joje leave it off for a couple of hours to satart working on it. Good luck.
Aug 26, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo AV Receiver turning off - by its self.
The space you have provided should be enough. If this is a new unit and still under warranty, I would request warranty service. It sounds like the unit is entering protect mode. This may be due to heat or it could be because of a defect in the protect circuit. In any case, this should not happen that quickly.
Update this if not under warranty and I'll provide a list of diagnostic tests to help determine the problem.
Dan
Jan 16, 2009 | Onkyo TX-DS787 Receiver
Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Jan 03, 2009 | Onkyo TX-SR705 Receiver
The picture via my Onkyo-sr674 has degraded
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Jul 10, 2017 | Onkyo TX-SR674 Receiver
Onkyo SV828THX Power on
There is or seems to be a bad or cold solder connection on that Printed circuit board that is going to need to be resoldered or it can cause more damage to the unit. And on this model, the fan will start at power up but shut down untill the output section heat sinks get hot.
Sep 28, 2006 | Onkyo TX-SV828DSP Receiver
56 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
