Question about Onkyo TX-SR706 Receiver
I have been having issues with the receiver "losing" the signal or interupting the signal from my blu-ray player and previously when using a dvd player. the DVD continues to run and when the signal returns I have missed 5-10 sec of whatever is playing. Sometimes this will happen every few minutes other times it will go a day without occuring. I know its the receiver due to when I plug the player into the TV no issues!!
    Brigadier General:
  • 8,546 Answers
That's one of several reasons I can think of to bypass the receiver's handling of any video I care about. I only let my receiver 'see' the audio from anything external and send it's own video to the TV so I can see its internal menus.
I don't know what can be done if your video-carrying cables are all good.
Posted on Jan 02, 2011
Projector Input is on DVI - Video. HDMI cable thru an adapter is plugged into DVI port. When av receiver has "TV" selected; Picture is projected. When Blu-Ray is selected; there is no picture....
The Sharp XR-30X will display 720P and 1080i. The Blu-Ray player is trying to send 1080P which requires a handshake. It sounds like you might have to go into the Blu-Ray player and tell it to use 1080i.
Mar 04, 2011 | Sharp XR-30X Projector
I have a 5.1 channel Insignia receiver that I'm using to set up a home theater system. I am connecting my Samsung blu-ray player to it with an hdmi cable. The sound and video work correctly until the...
I am going to take a stab at this one because it is interesting and hopefully it will help you. I see there are possible two issues to solve here. Lets do a test,
Connect the Samsung, using the HDMI cable DIRECTLY to the the HDTV. See what happens.
The reason I say this is because the Insignia Receiver is probably at least two years old. There have been several levels of HDMI Standard implemented in the last several years. That leads me to believe that he Samsung menu option signal may not be compatible with your receiver. To clarify this, take a look at the link below. It refers to the different HDMI Standards. 1.0, 1.1, 1.2, 1.3 and 1.4. When your receiver was introduced, I believe it complied with the 1.2 HDMI standard.
Hope this helps, Happy New Year, Mark
http://hometheater.about.com/od/hometheatervideobasics/qt/hdmifacts.htm
Dec 31, 2010 | Insignia Audio Players & Recorders
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
My new Blu-Ray player will not send out an HDMI signal, except when I turn it on. It shows the Blu-Ray sign, then stops sending out any signal. is this a common problem?
This is not a common problem.
It sounds like you are receiving signal from the DVD player, but are having a resolution issue. After the splash screen is when the resolutions setting can affect your output. What this sounds like is the DVD player is set to 1080P and the TV is only capable of 720P or 1080i. If there is a resolution mis-match, connect a composite cable to the TV and set the resolution of the DVD player to AUTO, then check to see if you have an image from the HDMI connection.
If your TV is capable of 1080P and if this solution does not fix the problem, and all other outputs from the player perform the same, the unit is faulty and should be returned if still under warranty.
Hope this helps!
Jan 11, 2010 | Insignia NS-BRDVD Blu-Ray Player
When trying to connect my 4695D to a new Sony Blu Ray player BD 560 using HDMI with the output set on the Blu Ray to 1080P I cannot get a signal to appear on the TV. If I change the output to 720P I am...
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
Dec 28, 2009 | Samsung LN-S4695D 46 in. LCD HDTV
Blu-ray player won't play through hdmi with yamaha reciever
The problem is some intermediate connections do not allow the HDCP signal to reach the telivison. Electronic HDMI switches have this issue. I have one HDMI port on my Telivision and I have a Blu-ray player & HD satellite reciever. I had purchased a two in one electronic switch and found that the satellite reciever signal would make it to the tv and was working but the blu-ray player was not. I had to by a passive push button switch and it allows the HDCP signal thru. The funny thing is the electronic switch was supposed to be HDCP compliant and it still did not work.
Sep 06, 2009 | Yamaha Audio Players & Recorders
Solution for "My sony sb 301 blu ray disk will not load It keeps
check with different Blu-ray discs and DVD discs. If the issue occurs only with some discs, then try updating the Firmware for the Blu-ray Player which should resolve the issue. Contact the Sony support team to get more information about the Firmware update for the Player.
May 09, 2009 | Sony BDP-S301 Player
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Onkyo TX-SR706 Receiver Logo
142 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
