Question about Microwave Ovens
HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
    Brigadier General:
  • 8,909 Answers
HOW DO I GET FILTER Problem with the Microwave Ovens HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
I am a little confused as I don't ever remember a microwave oven with brown water a filter and cleaning tablets!
Posted on Jan 01, 2011
Ptac suburban dynaline doesnt heat
I had the same issue with my unit - I just needed to clean the air intake filter. The system will lock-down if it isn't getting the right air pressure / overheating.
It's easy to do, you just grab the lower back sides of the cover and lift it up and away from the unit. The filter is at the front of the system and can be pulled up and out for cleaning. You can then clean the filter with water / soap water.
There are also instructions in the manual about checking the flame - you can do this while the filter is off. There's a little window into the burner and you should be seeing a predominately blue flame.
http://www.scribd.com/doc/12278321/Suburban-Owners-Manual-DL3-0712-to-1622#scribd
Feb 13, 2014 | Heating & Cooling
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
My iron is squirting out brown gunk from the steam holes under the iron itself. i have cleaned and rinsed it out. the manual says it is a gc 7430, gc7420.
Sometimes using vinegar and water will clean out your steam iron - but smells really bad. Usually the brown gunk is a sign that there is corrosion so even if the vinergar works, you should plan on buying a new iron in the near future.
Jun 22, 2011 | Microwave Ovens
Where is the lint filter
Most filters for MICROWAVE OVENS are located on the underside of the unit.
To access, just unplug the unit and remove the rotating glass tray from inside, then tip the unit up on its side or rear and make sure it is secure and stable there.
At that point you should see the access panels for the filters on the bottom. Some just pop out without tools and some require the removal of 1 or 2 screws to get it out.
Remove and clean / replace as per the instructions in your owner's manual.
Good luck.
Mar 10, 2011 | Microwave Ovens
When I boil water on the stove top, the electronic buttons on the microwave do not work. After a period of about week the electronic buttons work again. A repairman said I need a new door for $325.00. ...
CONTACT LG FACTORY TECHNICAL DEPTN, ASK IF THERE IS A SERVICE FLASH ON THIS MODEL OR INSULATION TO KEEP THE CONTROL PAD FROM FILTERING WATER STEAM..
Feb 18, 2011 | LG LMVM2075 Microwave Oven
After grinding coffee,can you submerse in water to clean
No!!! You can clean the cup that the coffee goes into, but do not get the grinder in the water...
heatman101
Nov 25, 2010 | Microwave Ovens
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Deep Cleaning techniques for GE spacemaker Convection microwave
Try simple green. It is great at eating through grease. It may take a few times but it works. It is biodegardable. I used it at one of my old jobs for cleaning grease off of glass and use it in my home as well.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
