Question about Microwave Ovens
Newest model plugs in but digital displacy says on NO and AC'F
    Brigadier General:
  • 8,909 Answers
And what make and model is that microwave then?
Posted on Jan 01, 2011
Kenmore brewnwave blows fuse
You have a short, if it does it when you plug the unit to power(not turned on and working) problem is where the wall voltage (AC voltage ) comes in and I would in that case look for the large AC filter cap to be buldged or out of its normal shape(photo attached of a typical one).
If it does blow the fuse when turned on to cook suspect the Diode that most use, the Magnetron that does the cooking or the inverter board that powers the Magnetron.
See attached photos of typical ones, some people can or cannot do this kind of repair but this will give you some possible reasons--when a fuse blows there is a short.
12_19_2012_2_46_22_pm.jpgTypical diode(should not read short across it.
12_19_2012_2_47_21_pm.jpgTypical Magnetron, cannot be tested easily but would have to be replaced to know--the units vary in shape very little..
12_19_2012_2_48_53_pm.jpgTypical AC cap, these will vary in shape as some are more oval but the outer part is metal coated with clear plastic. This can be tested with a ohm meter.
Dec 19, 2012 | Microwave Ovens
Replacing fuse in samsung microwave model number shm9187
there should be a fuse inside on the AC line and it may be on the inverter(power) board of the unit.
Nov 02, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Can this dishwasher wich is from france be used in england
You didn't state a make and model, but the voltage and AC frequency isn't a problem and French mains water pressure is very similar to the UK so it shouldn't be a problem. The mains plug will need to be changed though, but it's only ten minutes work to do that (don't use an adapter: very few are deigned for appliances with powerful heating elements like a dishwasher has).
Mar 17, 2011 | Microwave Ovens
F1 trouble code is flashing and BEEPING how do i get it to Quit
You can pull the AC plug and leave it overnight; the error may be only a momentary glitch.
If the problem persists, you may find it less costly to replace it instead of sending it for repair.
BTW, that F1 could mean different things on different units. You gave us neither the brand nor the model number.
Oct 24, 2010 | Microwave Ovens
ASKING FOR TIME OF DAY BUT WHEN I PUT IT IN IT WILL NOT DO ANYTHING WHEN I HIT THE START BUTTON. THIS MODEL DOES NOT HAVE A RESET BUTTON.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a bad keypad.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jot down your full model number and see here for more help.
Aug 22, 2010 | Kenmore 80012 Microwave Oven
No power. Checked AC connection and have power
Most microwave ovens come with a fuse. Typically it is a 20 Amp fuse. Be careful if you decide to open the cover, the the fuse should be close to the electrical wires coming from the plug. Hope this helps.
Jan 04, 2010 | Microwave Ovens
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wire Diagram
If the plug is not keyed and you cant tell from the wires, it probably doesn't make a difference. You are telling me it is 21 VAC ... AC dont care - and you dont appear to have a common ground situation.
Sep 07, 2009 | GE JE1460 Microwave Oven
Model MW1080sta Problem: Turntable won't turn at all. Trying to change synchronus motor. What voltage should it show when I plug in power? Wanted to test before replacing it.
Most ovens that I have repaired the turntable runs from 115 volt ac. Most ovens have a schmatic on the inside, look at it and follow the motor leads back to the sorce of power and check any switches or interlocks that it may go through.
good luck
May 17, 2008 | Samsung Microwave Ovens
DEAD
Make sure unit is not plugged in. Use a Volt-Ohm Meter, on Ohms setting, and see if you have connection to the fuse holder. Put one meter lead on the BLACK ac wire, test the ac plug with the other lead (both sides) One should read. Do the same with the WHITE ac wire. One should read.If you get readings on both sides then AC Cord is good. Next check the fuse holder for signs of heat or dis-coloration. If found replace fuse holder. Always remember just because a fuse looks good does not mean it is good, and also I have replaced a fuse with a NEW bad fuse. It happens. To be sure test with meter.
Jan 16, 2008 | LG LMV1650ST Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
