Question about Frigidaire Dishwashers
I have a Frigidaire dishwasher 7 yrs old, model FDB635RBS0 al small black piece broke off so the door will not latch shut when closed. Is this easily repairable? What's the average life expectancy of this model? Thanks so much Tom tomelie@juno.com
  • 210 Answers
SOURCE: Door won't latch to LG LDF6810ST
You have to pull out your unit about 3 inches to get to where the latch is screwed in. It is a phillips screw. The part number is 4026DD3001A. In the meantime to keep it closed you are going to have to get creative..
Sgt 48
Posted on Jun 02, 2008
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
jsrock516
  • 5911 Answers
SOURCE: the latch on the door broke and the machine will
This is a repair that you can easily perform yourself. The part number for the replacement latch is 5304442173. Go to repairclinic.com and type in the this part number and they will also include a new door gasket. All their parts ship with instructions on how to replace as well. Just make sure you secure power to the dishwasher before servicing. If you need assistance with replacing the part, please let me know. I hope this helps you.
Posted on Aug 19, 2009
  • 37 Answers
SOURCE: Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Posted on Oct 20, 2009
  • 3247 Answers
SOURCE: I have a frigidaire gallery
It would be helpful to have the full model number of the dishwasher.
Most likely the door seal is swollen and may need replacement.
Alternatively the micoswitch in side the latch assembly is not making contact with the latch tongue.
It is also possible the springs at the door base are too tight and need to be adjusted.
need the model number.
Posted on Mar 02, 2011
THE LATCH IS READING THAT THE DOOR IS CLOSED BUT I CAN OPEN THE DOOR WHILE THE DISHWASHER IS IN CYCLE. WITH THE SPRING INDISE THE DOOR BEING LOCKED IT WONT EVENT LET ME FULLY SHUT THE DOOR! ANY HELP.
Hello friend, thank you for your post!
From what you have described the spring from the latch is broken inside of the door and you are unable to close your Frigidaire dishwasher. You would need to disassemble the dishwasher in order to replace the latch or spring. This needs to be done by a professional technician as improper disassembly could results in personal injury. I hope this information is helpful to you. -Matt
Feb 19, 2016 | Frigidaire Dishwashers
Latch is not tight when closed
Something must be blocking the door from fully engaging. Pull the loading racks out and put them back after checking they are on track and roll freely. Good luck.
Mar 06, 2014 | Frigidaire Dishwashers
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
I have a Frigidaire FDB2410LDC3 Dishwasher. It was working great until my 5 year old fell on the door and it does not spring back up now. I tried looking with a flashlight in the sides and the springs...
Prhandle and latch.obably sprung the hinges. The reason it dont want to work right is the door latch is not latching properly and therefore it wont start. I would start by replacing the hinges and springs and the
Dec 30, 2009 | Dishwashers
BUT!
Happy Washing!
Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Frigidaire dishwasher door won't close
with aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
Dec 17, 2008 | Frigidaire PLD4375RFC Dishwasher
Sgt 48
May 12, 2008 | LG LDF6810 Built-in Dishwasher
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
