Question about Electrolux Vacuums
My prolux will not **** up dirt - Electrolux Vacuums
  • 694 Answers
Check the flex hose between the power head and body of the vacuum. If it's cracked, which is likely, there will be a substantial loss of suction at the brush area.
To remove, simply lay the prolux on it's side, pull out the end connected to the power head, then unscrew the end connected to the tank. Turn in a clockwise motion to do so.
To install new hose, screw into the tank in a counter-clockwise direction. When firmly in place, gently push other end into the power head. Manipulate it so it is all the way in.
Happy New Year!
Posted on Jan 01, 2011
I need a handle and the hose for a Prolux AllVac. I have requested from Prolux, but do not get an answer
Write the CEO or Vice President of Prolux and see if you can get any help. Tell them what happened.
Jun 14, 2017 | Prolux Vacuums
New bag indicator will not reset causing bare floor mode not to work at all and mode 2 not to vacuum dirt properly
Your top motor (suction motor) isn't running. Your vacuum has two motors in it. The top motor is the suction motor that runs on the first switch position and the bottom motor (brush motor) turns on with the second possition.
It could be the switch.If it isn't the switch, the only other thing it could be is the motor itself.
To check the switch, unplug the vacuum and then take the three screws out of the back of the handle. If you are comfortable with electricity, jump the black wire and the blue wire togeather and plug the vacuum into a electrical outlet. If the motor dosen't run, the problem is with the motor. If the motor runs, the switch is bad and needs to be replaced. You can get one at most any vacuum shop.
The motor could be bad or the carbon brushes can be stuck with dust. This is more involved and I recomend taking the vacuum to a vac shop that works on the "old" Electrolux vacuums. The new name for the "old" Electrolux is now Aerus Lux but you would probably get it repaired less expensively at another vacuum shop.
If you want to go into the motor housing you'll have to take the big screw out of the back of the handle and pull up on the handle to remove it. Next, remove the four screws holding the top half (motor housing) of the vacuum. Two screws on the back and two screws to the front inside of the bag housing. You'll need a long #2 phillips screw driver. Then pull up on the bag housing with a side to side motion.
With the housing removed, you will see the motor and can lift it out.
Check for any bad winding. You can smell them to check if you can't tell by looking at them. If they are burned, you will need to replace the motor.
To check the brushes, you will need a 5/16th" socket to remove the two bolts on the top of the motor and lift the top bracket with the carbon brushes off and see if the brushes move freely. If not moving or not long enough to touch the top part of the motor with the copper bars (the comutator) it would be best to replace the motor.
To reassemble the vac just reverse.
This is a long and difficult prosedure and I reccomend that you take the vacuum to a repair shop that works on the Electrolux.
Feb 09, 2014 | Electrolux Vacuums
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
How do you empty it?
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
Apr 27, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Roller brush on PROLUX is making a chattering sound.
sounds like its the bearings in the end of the brush roll
Feb 20, 2009 | Electrolux 5740 Upright Vacuum
Roomba works but the dirt stops at the filter. New filter did not help.
The robot dirt tray has a vacuum motor to assist the dirt flow from the floor brushes. Yours is not working. recheck the connections on the dirt tray.
Aug 18, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Vacuums Logo
90 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
