Is there a manual available for our (oldish!) califont model: Rinnai REU - 68ET?
2 Suggested Answers
  • 1015 Answers
SOURCE: I HAVE A REU-55FT AND
I think your problem is that you are exceeding the operating parameters of your unit. You will need to cut back on the flow rate with a control valve and experiment with what rate you are stiil getting good operation. I hope this helps you. Thanks.
Posted on Dec 20, 2010
Hi there i have an old rinnai tankless water heater model # REU-502 and i need a new thermocouple (pilot won't stay lit after i hold it on for ever)i have the original manual but no one locally can he
That unit has a 5 year warranty on the parts that you are talking about. The unit also is proprietary and you have to contact them for service.
Mar 31, 2014 | Rinnai Heating & Cooling
Rinnai REU 58e installation manual
try w.ww.rinnai.us then look under library . Or wwww.rinnai.au
Apr 10, 2011 | Rinnai Heating & Cooling
Ignition problem: I have a gas hot water system: RINNAI CORPORATION; MODEL:REU-2008W-A the panel display temperature as 40C, when open the tap, the temperature display dropped to 12C, and no...
This is an error code 12, not 12 degrees. You have a short on your low voltage side by the sounds of it.. First disconnect the controllers inside the heater. Turn of the power first, 2 screws top and bottom to take the frnot panel off. Follow the low voltage wires (not the power point ones) to the PCB on the ride side and disconnect them both. Panel back on, power on and try the heater again. If this fixes it you have a short circuit in the controller or the wires leading to it. If not the most likely short circuit is on the thermal fuse which loops around the heat exchanger. This will need an expert, Perth has plenty north and south of the river. Give Rinnai a ring first, they have some good staff in Perth who might help.
Dec 02, 2010 | Rinnai Water Heaters
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
I "think" I have pinpointed the problem but want confirmation before I buy this part. the sequence of "lighting " the pilot is working fine and the water flow is circulating as it should. when I "turn"...
To keep the Pilot running... TYPICALLY the instructions say hold the pilot down for 30 seconds to allow the thermocouple to assume control... If extending that 30 seconds a wee bit does not work and your "pilot" keeps going out...
You have indeed found your "trouble"
The obvious defferences being length (first
(see generic parts below)
Follow the instructions on the replacement &
- DO NOT overtighten...!!
https://www.bing.com/search?q=thermocouple+rinnai+REU-95GS&qs=n&form=QBLH&sp=-1&pq=thermocouple+rinnai+reu-95gs&sc=0-28&sk=&cvid=AE29392FA0A049CDA62B934C932F13A7
Generic
Amazon com replacement thermocouple
Carnac the Magnificent
Mar 11, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
